It is currently Wed Jul 30, 2025 5:46 am
 Post subject: Mini acting wierdly
PostPosted: Wed Jun 08, 2005 3:28 pm
Driving home from school today in the rain and the indicators stopped working, and so did the windscreen wipers. So it sucked driving home, having to hand signal and not being able to see through my windscreen :evil:
Strangs thing was, once i got home, and turned off the engine, the windscreen wipers and the indicators started working again...strange... :?
PostPosted: Wed Jun 08, 2005 3:42 pm
flat battery maybe???
i aint a mechanic but thats all i can think of
Nigel Morton/ Team Brickworx
never late in a 998
PostPosted: Wed Jun 08, 2005 3:46 pm
Possibly a relay problem??? :? Do you have a multimetre to run a check?
PostPosted: Wed Jun 08, 2005 3:52 pm
fuse or relay problem
PostPosted: Wed Jun 08, 2005 4:10 pm
Resident Haemorrhoid
ahhhhh Mr Lucas stikes again :twisted:
Welcome to the wonderfull world of Mr Lucas :wink:
Check to see if water is getting into the electrics somewhere causing a short. the fuses may look ok but may be the problem for the little cost involved replace the fuses to see if that helps..
Cheers Gadget
PostPosted: Wed Jun 08, 2005 4:11 pm
mini fuse boxes are crap-o, especially if they havent got a cover over them..
clean the whole thing up
PostPosted: Wed Jun 08, 2005 4:50 pm
The thing about this is that everything works, just not simultaneously. It sounds like one of your earths somewhere is fiddley, or something is earthing where it shouldn't.
Jonathan
PostPosted: Wed Jun 08, 2005 5:16 pm
My fuse box is usually the culprit for exactly the same symptoms.
I put a little bit of wet and dry sandpaper around a small bit of dowel and rubbed that around where the fuses sit in their holders. Made it all bright and shiny for a good contact on the fuse.
PostPosted: Wed Jun 08, 2005 6:04 pm
Fuse Box.
Don't blame Lucas for poor maintenance by the owner. :x
PostPosted: Wed Jun 08, 2005 7:25 pm
Two possibilities really:
A. Low battery charge state - and so your battery can not supply both the engine ignition system and headlights and wipers + flashers.
Possible Causes: Alternator belt too loose, loose connection on the battery, . Easiest way to see whether its the alternator or a loose battery connection -- see if your lights shine brighter with the engine off than with the engine on and the wipers on. Or check battery charge (DC not AC) - should be between 12.2 and 12.7v with the engine off with the mid-high 12s are the best. And the battery voltage shouldnt fall and idealy should rise with the engine on.
B. fuse box as said or at the line to it from the solenoid or at the solenoid itself. sometimes oxidasation on the terminals only allows contact at the fuse in a single position and the vibration of the engine displaces the fuse.
PostPosted: Wed Jun 08, 2005 10:45 pm
damn straight!! I've never had a problem with lucas electrics that wasn't caused by me or some other monkey....
it's definitely a dirty fuse, you'd probably find that more than just the indicators and wipers stopped - stop lights, temp and fuel guage as well probably...
PostPosted: Fri Jun 10, 2005 6:25 pm
thanks for the advice guys
PostPosted: Fri Jun 10, 2005 6:31 pm
teh admin God
teh admin God
good
so i decided to take the mini, instead of the rubbishbox magna, on a holiday this weekend, just long the coast to a mates home. So i decided to check if all lights work? brake lights, cause mother said only one works? And all was dead? no idicators brake lights or whatever. i just whacked whatever, and now they work again :wink:
but it was quite strange 8)
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
PostPosted: Fri Jun 10, 2005 8:10 pm
a good whack will always fix it! just like those old TV's
PostPosted: Fri Jun 10, 2005 9:22 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
camel your a bit strange........
but thats why we like ya :)
makka
Users browsing this forum: Bing [Bot] and 103 guests
