It is currently Thu Jul 31, 2025 1:01 pm
 Post subject: Ball Joint
PostPosted: Sat Jan 26, 2019 4:52 pm
Fitting a new disc brake system to our Mini and when I pumped grease into the lower ball joint grease came out a small hole behind the disc as seen on attached photos.
Has anyone ever came across this issue and suggestions on what to do.
Sent from my moto g(6) plus using Tapatalk
 Post subject: Re: Ball Joint
PostPosted: Sat Jan 26, 2019 7:28 pm
that's to grease the disc so they don't squeak. Just joking, isn't it a bolt hole for guard?
PostPosted: Sat Jan 26, 2019 7:45 pm
There is no thread in the hole.
PostPosted: Sat Jan 26, 2019 7:50 pm
No, the guard if fitted just mounts on the 2 caliper mounting lugs and the steering arm. If hole is threaded put a grub screw in. Or tap it first.
No idea why that hole is there, it's not on original hubs, or aftermarket ones I bought.
PostPosted: Sat Jan 26, 2019 9:08 pm
I think i’ve seen this before - i think some disc hubs had blank holes in them where the holes would be on a drum hub to hold the back plate on- dont know why though.
To fix it, i’d tap and grub screw plug it.
PostPosted: Sun Jan 27, 2019 7:57 pm
A couple of plugging options if you don't want to tap the hole. Years ago we used to plug holes in steel hydraulic manifolds with hardened steel balls (ball bearings). By tests we found a 0.250" diameter ball driven into a 0.242" diameter hole would withstand better than 6000 PSI. The same ball driven into a 0.249" diameter hole was good for 3500 PSI. Nowadays hydraulic manifolds are commonly plugged with Koenig expander sealing plugs which maybe another option http://www.schiltec.com.au/
Since there will be little or no pressure involved, a ball with a couple of thou interference should plug the hole forever.
PostPosted: Mon Jan 28, 2019 9:44 am
I'd be more inclined to contact the supplier and say "WTF?"
PostPosted: Mon Jan 28, 2019 3:40 pm
Thanks for your replies. I have contacted the supplier an I believe he wants to replace them.
Users browsing this forum: timmy201 and 102 guests
