It is currently Sat Jul 19, 2025 11:17 am
PostPosted: Sun Aug 04, 2019 7:12 pm
hey guys
Does anyone know if the remote housing from the morris 1100 is interchangable with mini?
(Same length?)
Rick
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Sun Aug 04, 2019 7:27 pm
The 1100 uses a rubber sandwich mount between the gearbox and remote housing.
They also have different bolt directions - mini bolts up from underneath and 1100 from the sides
PostPosted: Sun Aug 04, 2019 7:55 pm
Morris 1100 is longer.
Roads need more corners
PostPosted: Sun Aug 04, 2019 8:21 pm
My first car , a modified '61 850 had an 1100 engine with 1100 remote change with the said 'sandwich plate'. Kept on sheering the the bolts due to too much tongue.
PostPosted: Mon Aug 05, 2019 10:34 am
Ok. Thanks for that.
Rick
Ford DF LTD - 5Ltr
PostPosted: Mon Aug 05, 2019 11:42 am
People have been known to weld the sandwich plate up for a Mini, so it's solid. Gets rid of the rubbery Morris 1100 shifter feel.
PostPosted: Mon Aug 12, 2019 4:54 pm
The reason I ask is that I purchased basically a full 67 car in parts from a deceased estate. This estate also had morris 1100 parts and as the build progresses I am realising that I picked a lot of morris 1100 stuff. (Hardy spicers, drive shafts, steering column cowl)
Luckily based on above, the housing is mini as it bolts up from the bottom. The strange part is that it has a morris 1100 big rubber mount on the end (not the mini one). Possibly retrofitted due to its bigger size?
Rick
Ford DF LTD - 5Ltr
