It is currently Wed Jun 25, 2025 5:48 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Dec 29, 2019 9:54 am
Woody_Woodvine wrote:
gtogreen1969 wrote:
Large journal. Now just to get it measured and crack tested and machined and then start to worry about the bearings you need to buy.
I wanted to get it up to 1380cc and I know it will need a new crank with a longer through, new pistons due to the larger bore. Do I still need need to get the right journals?
You can offset grind the large journal crank to give more stroke. You will need to by small journal rods to suit after they offset grind it
PostPosted: Sun Dec 29, 2019 10:29 am
TK wrote:
a standard stroke with oversize pistons can get you to 1380. Remember to offset bore the block.
Why do you need a new crank?
I thought you used a non standard crank and oversized pistons to get to get to 1380
PostPosted: Sun Dec 29, 2019 10:44 am
Standard crank but overbored to 73.5mm gives you 1380cc.
The downside is you don't really have any more rebores once the engine wears. If you went +020 over, then next time you can bore to +040 etc
PostPosted: Sun Dec 29, 2019 1:35 pm
don't bore a standard block to 1380!!!!!!! or even up to 060
PostPosted: Sun Dec 29, 2019 2:10 pm
Then what's the best way to get more power other than twin su carbs or a 45 dcoe webber, a cam with higher lift or a better cylinder head
PostPosted: Sun Dec 29, 2019 2:58 pm
You need to match all the components to get a good result. Eg
Compression ratio
Cam
Cylinder head
Carb(s)
Ignition system
And also decide what your goal is regarding power/driveability etc
The difference from 1275/1293/1310/1380 won’t make as much difference as getting everything matched and working together.
PostPosted: Sun Dec 29, 2019 5:03 pm
Timmy is 100% correct
PostPosted: Mon Dec 30, 2019 8:26 am
Hi Woody. Without trying to be rude, do you know what a standard mini feels like on the road - a 1275 or thereabouts having about 60 horsepower at the wheels? I am only wondering because if you go to a lot of time money and expense to get approx 80 hp at the wheels you may still be disappointed or you may be delighted.
I am with the others regarding the block, DON'T overbore to the max on your first go. To add to Timmy's list a good exhaust manifold and exhaust helps flow for relatively small change ( commonly called a stage one kit in the UK)
PostPosted: Mon Dec 30, 2019 2:28 pm
Yeah I do, my grandfather use to have a cooper s with a 1275 and I enjoy the power, but I still feel I need a bit more just because I live in an area with lots of steep hill and more power and torque would go along way to making it a bit better.
PostPosted: Mon Dec 30, 2019 5:44 pm
Hmmm. A 1275 Cooper S should eat up steep hills.
The engine that you have if bored to 1380 would probably have less response than the 1275 S.
PostPosted: Mon Dec 30, 2019 9:15 pm
It did but I have a 1977 Leyland Mini sunshine with a 998. Abd the 1275 I know isnt a cooper s engine so I new I would need to make more power some other way and I instantly went to boring it out to make more power. Now I know that keeping it a 1275 and doing cam and head upgrades would be better.
PostPosted: Mon Dec 30, 2019 9:43 pm
Good to keep asking questions and good that you are armed with info beforehand.. good luck and keep us informed.
PostPosted: Tue Dec 31, 2019 8:27 am
Don’t know if this helps, but the 1275 I just had done was already bored to 0.040” and fortunately in excellent state, so no need to bore it further. This was then matched with cylinder head work, cam, carbie, exhaust, 3.4 diff etc. to produce a great road going 1310cc giving good torque from relatively low rpm for around town, and good acceleration on the highway and pulls like a train up hills.
So definitely agree with what Timmy was saying that it’s the sum of all parts that are correctly matched that will provide the biggest bang for the $
PostPosted: Tue Dec 31, 2019 11:30 am
4.3 diff???? Not with 10 inch wheels.
PostPosted: Tue Dec 31, 2019 2:37 pm
I have 12" rims with a higher profile tire arm. I'm got go down to a lower profile due to my tires rubbing if I go over a bump with more than 2 people in the car.
Users browsing this forum: No registered users and 114 guests
