It is currently Fri Jul 18, 2025 11:26 am
 Post subject: Test starter solenoid
PostPosted: Fri Jan 03, 2020 4:45 pm
Hi all
I’m trying to turn over the engine. When I turn the key to the first stop, I get dash lights and electric fuel pump runs. When I turn to start, nothing happens and no clicking noise. But I can get the car to turn over by jumping the two posts on the starter solenoid.
I’ve just pulled the ignition switch and cleaned and tested it which was fine. I’ve checked continuity of the wire from ignition to solenoid and that was ok.
How do I test the starter solenoid?
Australian 69 DeLuxe w/ hydro suspension. Single HS4 (twin HS2 being assembled). 1275 1100s engine (998 due for rebuild) . Clubman remote gear change. Automatic front subframe.
PostPosted: Fri Jan 03, 2020 5:45 pm
I found it on YouTube
www.youtube.com/watch?v=acCbXHG5uTs
Thanks FixitSam.
PostPosted: Sat Jan 04, 2020 4:20 am
Sounds like the ignition switch. I bought a new one with this fault. Took back...
PostPosted: Sat Jan 04, 2020 9:51 am
Yes. Tested using jumper cables and the faulty solenoid didn’t click. Gave it some percussive maintenance and it did open and close but got stuck open again.
Replaced with another one and got the engine cranking.
PostPosted: Sun Jan 05, 2020 11:50 am
****percussive maintenance****
Love it :D :D
1971 Clubman GT - Jet Red
1980 Mini 1000 - Bold As Brass
1967 Riley Elf - Red/White
2002 MINI Cooper - BRG/White
2005 MINI Cooper - BRG/White
2022 MINI Cooper SE - BRG/White
