It is currently Fri Jul 18, 2025 10:05 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Turbo time
PostPosted: Fri Jul 19, 2019 6:59 pm
Distributor turned up from Avonbar racing in the Uk today.
One more piece of the puzzle
PostPosted: Sat Jul 20, 2019 8:38 pm
Hi, what features do Avonbar offer with their distributor , and what total timing do they suggest ? Any boost retard ? Cheers Lindsay
1959 Austin A40 Farina fun car
1965 Mk1 Cooper S restored
1970 Colt 1100F SS restored
2014 Mitsubishi Imiev fully electric daily driver
1948 Allard M coupe Olds 215 v8 project
1971 Twin cam Escort ex Uk championship winning rally car project
PostPosted: Sun Jul 21, 2019 12:19 pm
Basically they asked what boost I’ll be running and set it to suit. So mines optimised for 8-10 psi
From their site: Turbo Electronic Distributor.Special advance curve for modified engines running higher boost than standard.Fully modified advance curve to suit Hi-boost applications. As used by us on all our modified Turbo engines. We now produce 3 different distributors 6-8 Psi - 8-10 Psi _ 10-14 Psi
Please state boost when ordering.
NOTE: Above 14 Psi we recommend Polestar or similar management systems.
PostPosted: Fri Jul 26, 2019 5:01 am
Head gasket, turbo oil hose new studs arrived today, time to get busy.
PostPosted: Sat Aug 10, 2019 5:46 pm
So all parts are present and accounted for.
Will begin the task
PostPosted: Thu Aug 22, 2019 4:18 pm
Painted head and mounted turbo to manifold finally.
Also got the bolts for mounting the plenum to my carb.... forgot to snap a pic of that though
PostPosted: Mon Aug 26, 2019 8:06 pm
Pulled my engine out today, bolted a head on and dummy fit the turbo setup.
Tight fit
But it does all fit, no fowling.
Need to do oil feed and return lines now.
PostPosted: Wed Aug 28, 2019 3:47 pm
Set the timing yesterday,
Torqued down the head today, no time for much else
PostPosted: Thu Aug 29, 2019 11:31 am
It’s a really neat manifold setup isn’t it? Looking forward to seeing your progress
PostPosted: Wed Sep 11, 2019 8:32 pm
Looking good. I'm doing a much longer-term, much reduced cost version :) I'll be interested to see how it comes along, with timing options etc.
PostPosted: Sat Sep 14, 2019 5:05 pm
Keen to see your oil feed and return set up. Looking really good. Well done!!
-----Better is the enemy of good-----
-1976 Yellow Devil Leyland Clubman-
-1970 Morris Mini Van - Work in progress-
PostPosted: Sat Sep 14, 2019 6:20 pm
Chris.Williams wrote:
Kennomini wrote:
Cool, is their any concern about extra heat on the firewall?
There has been no mention of it, but I’ll be applying some protective heat shielding to be safe.
Considering a turbo blanket, doing more research first.
Here's some of my heat mitigation...
For my turbo build I'll also be adding turbo blanket too - I think that's a good call.
Edit: also, I don't have a pic handy, but I use this stuff as heat shield, cut and bent as needed.
PostPosted: Fri Nov 01, 2019 6:59 pm
Dropped the motor in to check fitment, no fowling so that’s a positive.
Need to clock the turbo a touch more.
Done a mock up for the intercooler piping while I was at it.
PostPosted: Thu Jan 23, 2020 6:48 am
How’s this going Chris? Any progress from the mock up?
1963 850 - laid up
