It is currently Sat Jul 19, 2025 9:06 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jan 23, 2020 6:46 am
Bill B wrote:
Check out website on the box in one of Morbo28 photos.
http://www.gsl.eu.com
Global Supplies and Logistics offer branding and packaging with any name the customer wants as part of their services.
Cheers Billy Boy...maybe that lot should be referred to that toothless tiger the ACCC for promoting false advertising! :roll:
PostPosted: Thu Jan 23, 2020 7:48 am
In old news the Chinese have been selling bootleg bearings in OEM boxes eg Timken, SKF etc for years through some parts shops. IMO your best chance of buying originals is through a bearing shop.
No, I'm not suggesting RHP bearings from Mini shops are dodgy.
PostPosted: Thu Jan 23, 2020 8:33 am
Reminded me of the time (1990s?) when the RHP double row bearing became unavailable for a long period. Then a poor quality alternative came onto the market; then a better German made one; finally RHP came back to much relief.
PostPosted: Thu Jan 23, 2020 7:43 pm
Sorry to keep harping on, but just arrived today:
New adjustable tie rods from - guess who? "GSL" - the new MOWOG.
PostPosted: Fri Jan 24, 2020 8:52 am
Please keep harping on Bill, as will I. I know of a recent case where brand new wheel bearings in the proper packaging, fitted by a knowledgeable garage, both collapsed within a week.
I shudder to think what ball joints have become, an achilleas heel in the Mini at the best of times. Australians (and others around the world) will be/are being put at risk of serious injury or death...
PostPosted: Fri Jan 24, 2020 10:59 am
"I shudder to think what ball joints have become, an achilleas heel in the Mini at the best of times. Australians (and others around the world) will be/are being put at risk of serious injury or death..."
A bit too late mate. I Mini owner up here bought some ball joints from a mini supplier in Victoria. The ball joint collapsed at 80kph and the mini hit a tree. The driver spent three months in hospital. The supplier said that he wasn't responsible. Bullshit
PostPosted: Fri Jan 24, 2020 1:23 pm
little FYI if you’re going to check the lay shaft with a file. Do it in the centre where the bearing doesn’t run (not on the taper but towards the middle). The whole shaft is hardened (if it’s been hardened) and you don’t risk any damage to the bearing surface. Obviously it’s a moot point if the shaft is made of cheese but better to err on the side of caution.
PostPosted: Fri Jan 24, 2020 1:33 pm
Lol yes I didn't file the bearing surface :D
Sent from my Pixel 2 XL using Tapatalk
PostPosted: Fri Jan 24, 2020 2:35 pm
Yesterday I tried the file test on the newest layshaft I just bought and compared the results with the old shaft that had been in use for 30 years. They actually both showed marks but could not really feel anything.
The newest one came in a blue box like Morbo28's photo, however, the tapered section between the 2 diameters on mine is the same colour as the rest of the shaft and not a dark steel. Perhaps this one might be good to go.
PostPosted: Fri Jan 24, 2020 4:40 pm
Its not a p1 double S-ing contest but I have been posting stuff like this for over a year...
PostPosted: Mon Jan 27, 2020 5:10 pm
https://www.ebay.com.au/itm/mini-morris ... Sw~JFcWXs1
quality?
PostPosted: Mon Jan 27, 2020 6:29 pm
TK wrote:
https://www.ebay.com.au/itm/mini-morris-leyland-gsv1125-rear-trailing-arm-repair-kit-quality-oem-spec-x2/273958643157?hash=item3fc93525d5:g:ePMAAOSw~JFcWXs1
quality?
I bought a pair the same brand from Karcraft. They seem good, nuts not loose, fitted well on my son's Clubby.
PostPosted: Tue Jan 28, 2020 11:47 am
same box as Bill B's photo. GSL
PostPosted: Tue Jan 28, 2020 1:51 pm
The problem with GSL is they only source the supply of the item; I doubt they would exercise any quality control. So there would be good, bad and indifferent standards, depending on the item, who actually made it and whether they understood how the part was to be used.
