It is currently Mon Jul 21, 2025 7:31 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Apr 04, 2020 4:59 pm
gtogreen1969 wrote:
Sorry mate. My brain is not working good at the moment. Just had back and neck surgery
OK, good enough excuse. I look forward to your return to full fitness soon. ;)
PostPosted: Sat Apr 04, 2020 6:13 pm
7 & 34 look like morris minor clutch throw out bushes
12 is morris minor fork pivot retainer
35 mini clutch over throw nut
20 subframe tower lock tab
21 subframe tower spacer
36 looks like morris minor exhaust mount hanger
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Apr 04, 2020 7:03 pm
42. Accelerator pedal stop
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Sun Apr 05, 2020 7:58 am
36. Looks like a Mini Matic exhaust bracket (with a little extra welded on)
Could you have a look at one of yours to confirm? It bolts at the bottom of the engine/back of the diff housing.
PostPosted: Sun Apr 05, 2020 9:39 am
4. Is a little bit of trim from a clubby dash
PostPosted: Sun Apr 05, 2020 11:16 am
It looks a bit like the accelerator pedal stop but I think it might be a little bracket under the windscreen crossmember that holds the parcel shelf trim in place.
PostPosted: Sun Apr 05, 2020 2:19 pm
Yes. That's it. I took a look at an engine that I had on the floor. It still had that bracket attached.
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Sun Apr 05, 2020 4:47 pm
Thank you to everyone that has contributed.
Users browsing this forum: Bing [Bot] and 78 guests
