It is currently Sat Jul 26, 2025 11:05 pm
PostPosted: Tue Apr 14, 2020 10:09 pm
Hi all,
Wondering if anyone can clarify.
I have two harmonic balancers, one from an 850 and the other from a 998 A+ (998 is replacing the 850)
With the dual belt (which ive never come across before) will I run i to clearance issues with the radiator mounts if going into a standard 850?
Or, just bolt on the old 850 balancer and be done with it?
PostPosted: Tue Apr 14, 2020 11:52 pm
The dual pulley was for a pollution air pump on a Clubman. Just use the single and avoid the problem entirely if you like.
PostPosted: Wed Apr 15, 2020 8:18 am
There is only one solution here, use the dual pulley to drive a supercharger.
PostPosted: Wed Apr 15, 2020 8:45 am
I wish!
PostPosted: Wed Apr 15, 2020 2:39 pm
They aren't Harmonic Balancers they are just engine pulleys.
I believe that a duel water pump pulley was used for the air pump on Leyland Minis (Clubmans) not the engine pulley.
PostPosted: Wed Apr 15, 2020 4:05 pm
Thanks for the replies everyone. Standard 850 pulley it is.
PostPosted: Wed Apr 15, 2020 6:28 pm
Check for cracks around the rivets.
PostPosted: Thu Apr 16, 2020 10:44 am
Clubby and late Moke 998s had a cast iron pulley not sheet metal. Stronger.
PostPosted: Thu Apr 16, 2020 12:40 pm
Looks to be ok and usable.
If anyone has a later cast one that will fit without issues, feel free to get in contact with me.
