It is currently Mon Jul 21, 2025 9:22 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Engine Vibration
PostPosted: Fri Apr 24, 2020 9:25 pm
MINI66 wrote:
Morris 1100s engine is a 1275. Mine is 1293. 20 thou over I think. Yeah I have heard a lot about the large journal crank harmonics. This one is pretty bad though, maybe the light flywheel makes it worse?. I have another mini with a 1275LS engine so basically the same thing and it is not too bad. It doesn't have a harmonic balancer either. I will get the flywheel balanced I reckonk
I bet it’s not as bad as mine :D
From what I understand, the harmonic balancer doesn’t address this “harmonic”. Also, from what I’ve been advised, the light flywheel probably does not help. Mine has standard flywheel though and still vibrates like a bastard. I drive around town in 3rd gear at 60k/h just to avoid it - and so I can see out of my rear vision mirror!
PostPosted: Fri Apr 24, 2020 9:42 pm
This one doesn't seem too bad once your mobile. It is bad when stationary though. Thanks for the feedback. At least I'm not alone and leads me to think it will not be a reliability issue but more of an annoyance
Sent from my SM-G950F using Tapatalk
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Fri Apr 24, 2020 9:45 pm
Yep, I wouldn’t be worried about too much. Most folks think I have solid engine mounts in mine it vibrates so much.
PostPosted: Sat Apr 25, 2020 5:32 am
Even the 1275 Cooper S was criticized for rough running when released. Not much has changed...
However, my 1412 stroker was quite smooth when built, it had a lightened stock flywheel, but not ridiculously so.
PostPosted: Sat Apr 25, 2020 7:56 am
Drmini do you think a light flywheel helps or makes it worse?
PostPosted: Sat Apr 25, 2020 9:04 am
I think flywheel lightening helps but a race steel flywheel is too light for the road IMO.
Makes drop gears rattle more at idle.
PostPosted: Sat Apr 25, 2020 10:10 am
Oh dear, worry, worry...
HI Mini66
One thing that will make them vibrate at idle is if the centre main is on the way out, do you have good oil pressure?
Are the straps on the flywheel bent? is the backing plate central to the flywheel?
The flywheel would have to be a long way out of balance to make it vibrate badly at idle.
I can check it for you but the freight down and back will be expensive, and freight is very slow at the moment with AUS Post.
Nearly quicker to drive down with it I can do it while you wait for a packet of Monty Carlos and a smiley face :)
Graham russell
PostPosted: Sat Apr 25, 2020 10:25 am
G'day Graham
The idle is pretty smooth. Vibration is at about 1800-2000 rpm and smooths out again after that. New engine only about 20kms testing on it so far. Good oil pressure 50psi idle to about 75psi when revved. Generous offer mate but this car isn't rego'd yet. I havent pulled the flywheel yet, job for this arvo. Just tuning the weber right now. I will get back to you.
Rick
Ford DF LTD - 5Ltr
PostPosted: Sat Apr 25, 2020 10:34 am
Just realised you meant drive down the flywheel itself not the car.. All good mate I am in no hurry, I will get back to you after I wrestle this thing off with engine in situ. Always done it engine out in the past so this could be fun!
Ford DF LTD - 5Ltr
PostPosted: Sat Apr 25, 2020 11:32 am
Please let us know how it goes mini66, really interested to see if you find anything.
PostPosted: Sat Apr 25, 2020 6:49 pm
Problem found. Bolt and spacer missing from clutch. See attached. Not loose in clutch housing either. Made up some replacements and the weight is 37 grams. No wonder it was vibrating. Unfortunatly it turns out that the thread is stripped. Can you helicoil steel at 3/8 unff?
Wild looking flywheel!
Ford DF LTD - 5Ltr
PostPosted: Sat Apr 25, 2020 7:21 pm
Not all butchers wear aprons.
Good catch.
PostPosted: Sat Apr 25, 2020 8:16 pm
Hmm :(
PostPosted: Sun Apr 26, 2020 7:51 am
Those straps are back to front unless the image is reversed. Flywheel bolt should be to left of backplate bolt.
Flywheel rotates anticlockwise.
If image is correct, the straps are in compression underer load, not tension. No wonder it vibrates if so.
PostPosted: Sun Apr 26, 2020 8:31 am
Hey mate
Picture is not in reverse. I am trying to source a new flywheel at the moment.
Was going to helicoil it but being a homemade jobby I don't trust it. Your comments just add to that decision. All of the bolt holes are 3/8 instead of 5/16.
Edit. Sorry I have taken that in reverse somehow. Strap bolts are to the left in real life
The clutch seemed to be working ok with just the 2 straps albeit it was adjusted a fair way in (fair bit of load still on the release bearing whilst clutch engaged)
I did some quick research and 37grams doesn't seem a hugh amount in flywheel balancing terms. I really hope this is the prob. I am 90% sure it will be. Home bodged fw is probably out on its own before adding clutch compnents
Ford DF LTD - 5Ltr
