It is currently Sat Jul 19, 2025 9:09 am
PostPosted: Fri May 22, 2020 4:18 pm
I need to buy a central oil pickup for a fresh gearbox build. The last one I bought was actually handmade locally by a Mini racing engineer 25 years ago...
So, has anyone had experience of buying one from the usual suspects? They all look the same in the grainy website photos - are any better/worse than others?
PostPosted: Fri May 22, 2020 9:14 pm
I've only bought the Minispares ones.
I think most others just resell these.
They fit fine in a rod change box.
If you put them straight into a 4 synchro remote shift box, the filter mesh often fouls on the reverse shift lever. Which wears a hole in the mesh...!
Solution:
Squeeze the top bend gently in a vice with soft jaws to move the mesh and pipe forward 2 or 3 mm.
Test fit before final install.
PostPosted: Sat May 23, 2020 10:03 am
My MSpares item is still working fine. Really there are only two things to look out for; A that it fits and B that it has a reasonably large mesh area...
After 30 years I can't remember if we had to massage it to fit...
Cheers, Ian
