It is currently Sat Jul 19, 2025 6:49 pm
 Post subject: What is this hole
PostPosted: Sun Jul 05, 2020 1:13 pm
I think the motor is from late model moke
 Post subject: Re: What is this hole
PostPosted: Sun Jul 05, 2020 2:20 pm
Dowel hole. There is another down the bottom, behind your hand. To align the flywheel housing with the gearbox casing.
PostPosted: Sun Jul 05, 2020 7:18 pm
Thanks Doc,
It's a 1275 motor that is going into a Deluxe. Looks like it is a bit of hybrid though. No dowel where the hole is. Not all early idler/clutch housings have that hole though.
PostPosted: Sun Jul 05, 2020 8:50 pm
The dowel in there didn't always align if you mixed housings and gearbox cases. Over the years I built 2 boxes which needed one dowel or the other left out, to align the outrigger bearing.
