It is currently Sat Jul 26, 2025 11:32 pm
 Post subject: Primary Gear Spacer
PostPosted: Thu Aug 27, 2020 9:21 am
Where can I gear a good replacement for this part.
 Post subject: Re: Primary Gear Spacer
PostPosted: Thu Aug 27, 2020 11:02 am
I bought mine from here
https://classicmotoring.net.au/search.p ... +gear+shim
Obviously you need to measure clearances to figure out which one you need.
PostPosted: Thu Aug 27, 2020 11:11 am
'Morbo28" Not that shim. It goes on where the oil holes are, where the oil seal runs.
PostPosted: Thu Aug 27, 2020 11:13 am
Ah!
PostPosted: Thu Aug 27, 2020 11:17 am
More than half the primary gears I've seen out there are missing that oil slinger. These days with decent seals they work fine without it.
Edit
The black Rover MPI seal allegedly seals better according to one Mini repairer (not GR) I know.
I've not had one leak either.
