It is currently Sat Jul 19, 2025 9:21 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Carb rebuild
PostPosted: Tue Sep 01, 2020 9:00 am
simon k wrote:
If you don't want to keep the old needles just take out the screw and pull the needles out with a pair of pliers. It's a bit harder if you want to keep them... I take the screw out and drill a small dimple in the needle shank through the screw hole, then lever it out with a stiff scribing tool, someone else probably has a better way but that's what I do..
I will check it under a magnifying glass if there are some flat spots on the existing needle. If there are some then I got to replace it. what you are saying Simon is that needle is set in the damper that hard that destroying it with a pair of pliers or drill and lever it out from there....wow
Thanks,
1973 Clubman GT - YG2S8 1637
PostPosted: Tue Sep 01, 2020 12:05 pm
Thanks,
yeah, they're usually stuck in there pretty well. The lacquer type substance that is left when fuel evaporates gets in around the shank of the needle and sets hard. You could try soaking it in carby cleaner?
PostPosted: Thu Sep 03, 2020 10:49 am
Does anybody know what size those screws are that keep the butterfly on the shaft in place? I could not find any button head screws on Guam
PostPosted: Thu Sep 03, 2020 11:17 am
5BA
Sent from my moto e6s using Tapatalk
PostPosted: Thu Sep 03, 2020 11:35 am
Thanks Im gonna try Ebay
PostPosted: Thu Sep 03, 2020 12:06 pm
Part No is AUC1358.
The ones I can see on ebay are expensive.
Do the UK Mini Shops deliver to Guam?
http://www.minispares.com/product/Classic/AUC1358.aspx
http://www.somerfordmini.co.uk/eshop/in ... s_id=13523
PostPosted: Thu Sep 03, 2020 5:02 pm
Mini Spares does ship to Guam it just takes a while. The screws on my original butterfly and shaft are cheese head screws not like AUC1358. I will just use those with Locktite they have a smaller profile.
PostPosted: Wed Sep 09, 2020 8:29 am
I have only one of these. Is there supposed to be two? What is this called? Can I buy this? Thanks
PostPosted: Wed Sep 09, 2020 9:07 am
It’s an overflow hole cover. If the float needle gets stuck it’ll send fuel out of the hole there, that cover makes it dribble onto the lid and not put into the engine bay. Ideally you’d have both fitted
PostPosted: Wed Sep 09, 2020 10:48 am
Thank you
PostPosted: Wed Sep 09, 2020 1:27 pm
Part number is AUC1215. Google will show you can buy from numerous places.
https://www.classicminispares.co.nz/sto ... lid-baffle
PostPosted: Thu Sep 10, 2020 10:52 am
Thank you I just placed an order from this link
PostPosted: Thu Sep 10, 2020 10:53 am
does the housing for the float valve have a washer when screwed on to the float lid? Thanks
PostPosted: Sun Sep 13, 2020 6:54 pm
Too bad they wont ship to Guam
PostPosted: Sun Sep 13, 2020 7:50 pm
yes!
Users browsing this forum: jason050377 and 73 guests
