It is currently Thu Jul 24, 2025 6:36 am
 Post subject: HS4 Carb help
PostPosted: Sun Oct 11, 2020 9:18 pm
Hi all, I'm hoping someone may be able to help.
I'm fitting a HS4 to my 850 and have hit an issue.
Carb is a HS4 waxstat with carb spacer and it does not clear the bulkhead.
I have a spare pre non waxstat HS4 that I was hoping to remove the jet and linkages and put them on the Waxstat carb.
I know there are kits to convert, but was hoping this can be swapped.
 Post subject: Re: HS4 Carb help
PostPosted: Mon Oct 12, 2020 6:59 am
Yeah, you can swap parts around to make up what you want, it'll be fine
PostPosted: Mon Oct 12, 2020 7:52 am
Thanks Simon.
Just realised the spare I have is a RH and the waxstat is a LH so it may not work if the linkage is on the reverse side.
I will play around with them today.
