It is currently Thu Jul 24, 2025 6:58 am
PostPosted: Thu Dec 17, 2020 2:25 am
Hi guys, just wondering if you could help out, Is there a difference between the Mk 1 Cly head compared with the Mk 2, and what are they?
I have a Cooper S head that has been cleaned and crack tested OK, hence want to be able to give correct info for advertising.
Thanks Col.
PostPosted: Thu Dec 17, 2020 7:37 am
Part number cast on top-
12G163 is MK 1
Edit no it's AEG 163
2A185 is very early MK 1
12G940 is MK 2, casting shared with other 1275 motors. eg. Morris 1100S.
Cooper S head usually stamped 12G1805 near thermostat.
Last edited by drmini in aust on Thu Dec 17, 2020 12:27 pm, edited 1 time in total.
PostPosted: Thu Dec 17, 2020 9:54 am
12G163 is MK 1.
AEG163
PostPosted: Thu Dec 17, 2020 12:23 pm
12G163 is MK 1.
AEG163
Thanks, edited.
my bad memory. :oops:
PostPosted: Thu Dec 17, 2020 3:13 pm
A bit more trivia.
IIRC, very early MK1 heads were painted yellow under the rocker cover and later heads were painted blue.
Yellow ones were modified to improve ?????? cooling or cracking or ???? - (kraft disease problem)
I can't access the Special Tuning docs right now which have more info.
RonR
68 build Mk1 Cooper S
PostPosted: Thu Dec 17, 2020 6:53 pm
What was an AEG165 used on , I have one , it looks identical to the AEG163
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
Users browsing this forum: No registered users and 118 guests
