It is currently Wed Jul 23, 2025 9:23 am
PostPosted: Wed Jan 06, 2021 1:23 pm
These have been NLA for a while now.
14A7387 is part number. According to my pub1052 parts list. 2 per door.
I have just machined some alloy ones up, can do more if needed.
Edit:
Failure to fit this washer can result in distortion of the doorskin at the hinge.
Price TBA but won't be expensive.
Last edited by drmini in aust on Wed Jan 06, 2021 2:29 pm, edited 3 times in total.
PostPosted: Wed Jan 06, 2021 1:41 pm
Is that part number 14A7387??
PostPosted: Wed Jan 06, 2021 2:06 pm
My bad.
It's on the rear hinge stud, and the front of door bolt, called distance piece. 2 per door.
P/ no 14A7387.
Will change part number on original post.
Edit:
The special washer mentioned ( item 17, but not shown) in parts list is a large diameter thin flat washer, it bends to fit the door skin curve.
On rear stud only.
PostPosted: Wed Jan 06, 2021 7:15 pm
Available from minispares.... Bought a bunch in my last order.
http://www.minispares.com/product/Class ... o%20search
Well done though Doc
PostPosted: Wed Jan 06, 2021 7:41 pm
Minispares, look like they where made with a hacksaw.
PostPosted: Wed Jan 06, 2021 7:52 pm
Thanks guys.
I looked here in Oz a while back, I think John Smidt had some but nobody else.
PostPosted: Thu Feb 25, 2021 8:44 am
There are NLA descibed as "Washer-special-rear servo top hinge" washers used on the door hinges, not sure where they fit or the dimensions, any help would be appreciated as I need some for my resto.
PostPosted: Thu Feb 25, 2021 9:16 am
https://minisport.com.au/mini-mk1-mk2-e ... led-spacer
PostPosted: Thu Feb 25, 2021 9:34 am
Agree with Cooperess. The photo of the ones on Minisport.com.au site look they were cut with a hacksaw by someone in a hurry!
1965 MK1 English Morris Cooper S (Downton)
1967 MK1 Morris Cooper S
1972 Clubman GT (6/72 Cadiz)
1968 MG Midget
PostPosted: Thu Feb 25, 2021 1:57 pm
My bad.
P/ no 14A7387.
Edit:
On rear stud only.
Yes, 2 per door on the upper hinge and two per hinge mounting panel (the short part of the hinge) for these hinges as well.
