It is currently Wed Jul 23, 2025 9:28 am
 Post subject: K&N Spin On Oil Filter
PostPosted: Sun Feb 21, 2021 5:16 pm
Folks,
Forgive me if this has been posted before! For those who would prefer parts made somewhere other than China I found K&N oil filters at Supercheap. Made in the USA. As you might expect, 50% more expensive than Ryco.
Ian
'66 Mk 1 Cooper S,
'69 Mk 2 Cooper S,
'81 Leyland Mini (in New Zealand),
'78 Clubman 'Special' (track car)
PostPosted: Sun Feb 21, 2021 5:42 pm
Good buys can be had on the likes of eBay.
PostPosted: Sun Feb 21, 2021 5:47 pm
I recently bought 4 Cooper (Chinese) oil filters on eBay. 2 leaked at the crimp.
Also had 2 Ryco Z9s do the same.
I've gone back to Wix (made in Poland).
And Wix USA for the Z9s.
Last edited by drmini in aust on Sun Feb 21, 2021 8:44 pm, edited 1 time in total.
PostPosted: Sun Feb 21, 2021 6:42 pm
I haven't used Ryco oil filters since I found metal shavings inside the filter. I also use Wix now (51348). Purchased a few last year and are made in USA.
1963 Morris 850
PostPosted: Sun Feb 21, 2021 8:41 pm
https://www.wixfilters.com/About/PlantLocations.aspx
Phil
PostPosted: Mon Feb 22, 2021 7:07 am
Did you investigates why there were metal shavings in the filter? and did you thank Ryco for showing you that you had an engine problem :?:
PostPosted: Mon Feb 22, 2021 10:40 am
New out of the box and before you had fitted it?
PostPosted: Mon Feb 22, 2021 4:23 pm
Ryco filter was new out of the box. Went to lube rubber seal and there was a small metal filing sitting on rubber seal. Though mmmmmmm. Turned filter upside down and tapped it in the palm of my hand, couldn't believe what came out of the middle of the filter. Would say about 20 or so metal shavings. Not good.
1963 Morris 850
PostPosted: Mon Feb 22, 2021 5:44 pm
Hmmmmmm NOT GOOD...did you you report it to the supplier? RYCO website etc????
PostPosted: Mon Feb 22, 2021 7:07 pm
Took it back to supercheap, got a refund. They said they would follow it up but never heard back.
1963 Morris 850
PostPosted: Wed Feb 24, 2021 11:03 pm
OMG
PostPosted: Thu Feb 25, 2021 11:52 am
I wonder if some people think they can clean the K&N oil filter too...
PostPosted: Thu Feb 25, 2021 3:34 pm
Funny you should mention cleaning K&N filters. I have had mine for a long time now and have never bothered to clean it. My reason being that Vizard tested a K&N air filter deeply covered in dust after one of those Baja desert races and it still flowed well compared to paper filters!
