It is currently Fri Jul 18, 2025 12:41 pm
PostPosted: Mon Jul 19, 2021 4:07 pm
Anyone tried this one?
PostPosted: Mon Jul 19, 2021 5:45 pm
My google can't find it.
PostPosted: Mon Jul 19, 2021 6:07 pm
Repco version. I called in there today but nil stock.
PostPosted: Mon Jul 19, 2021 6:09 pm
https://www.repco.com.au/en/parts-servi ... p/A9513092
PostPosted: Mon Jul 19, 2021 6:45 pm
I would suspect most 3veryone has changed over to spin on cartridge which are a much better, cheaper and cleaner option.
If originality is important then I suggest an original imported from one of the UK suppliers.
Cheers Dave.
PostPosted: Mon Jul 19, 2021 8:10 pm
No, just effort involved in changing over is lacking.
PostPosted: Wed Jul 21, 2021 10:21 am
Ryco R2200P filters still don't have the 2 seals.
I am still using the cartridge style filters. It is a bit messy but not the end of civilisation.
Mini Spares UK have these seals separately:
http://www.minispares.com/search/classic/508380.aspx
These 2 seals fit the Ryco 2200 filter unit (Aust'n made) but the O ring for the outside of the cannister isn't thick enough for Cooper S cannisters (UK made) which also use a different cartridge.
PostPosted: Wed Jul 21, 2021 2:04 pm
You can get odd sized O rings from most bearing shops.
PostPosted: Fri Jul 23, 2021 1:00 pm
Can buy the 2 oil seals from Minispares UK
1970 Cooper S SPO41
