It is currently Sat Jul 19, 2025 1:50 pm
 Post subject: Build Plate
PostPosted: Tue May 10, 2022 9:27 pm
Hey all,
I'm an hour away from my mini, but need to get rivets to reattach the build plate.
What is the factory sized holes in the firewall for Aus built mk1 850?
Thanks
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
 Post subject: Re: Build Plate
PostPosted: Tue May 10, 2022 10:28 pm
PostPosted: Wed May 11, 2022 12:09 am
eightfifty wrote:
Well here's an excellent example what we've been talking about in a previous post. If you were to just observe another car at a show, the chances are that you will see aluminium rivets from a hardware store which are completely wrong. The correct rivets for the identification plate are part no. 97H728 (DMP824) which is a monel rivet 1/8 diameter with a head diameter of 0.236". I purchased some of these from a supplier off Ebay last year although the items I purchased were a little long, they worked very well and look authentic. Search ebay for:
Qty 25 Dome Rivet 73 MS 4-6 Monel / Steel 1/8 - 3.2mm x 12.7mm Nickel Co...
It still comes up.
Regards
Tony
Just ordered a pack.
I take some delight in finding parts that are still available and close to original. It's a quiet life here in the suburbs, in the shed and avoiding the gardening.
Please don't tell me the factory changed the specifications just before my model was released....
PostPosted: Wed May 11, 2022 6:16 pm
I'm sure they only changed it 2 or 3 times...
Users browsing this forum: Bing [Bot] and 73 guests
