It is currently Sat Jul 19, 2025 8:43 am
PostPosted: Tue Jul 12, 2022 12:10 pm
Apart from the stamped numbers on the left, what is the difference from a Mini 4 synchro box and a Coopers S 4 synchro box?
PostPosted: Tue Jul 12, 2022 12:35 pm
Gear ratios, Hardy Spicer outputs
PostPosted: Tue Jul 12, 2022 2:46 pm
The 1st motion shaft gear with 18 teeth is a major difference and a Cooper S Laygear.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Wed Jul 13, 2022 9:41 am
Your title says "case differences" and you said "apart from the stamped numbers", the answer is "absolutely nothing"
PostPosted: Wed Jul 13, 2022 10:58 am
Just want to be sure that a non FAXE case is ok to fit a Mk2 engine.
PostPosted: Wed Jul 13, 2022 11:17 am
Yep, no problem at all.
The only tangible difference in the gearbox case assembly is the diff side plate covers, but obviously they're very interchangeable. I have pot joints on my FAXE case
*cough*IdohaveaspareFAXEcaseifyouwantonethough*cough*
