It is currently Mon Jul 14, 2025 11:47 pm
PostPosted: Tue Sep 06, 2022 2:36 pm
Hi all,
The clutch housing on my 3 synchro is munted following an idler bearing failure previously.
I have a spare 4 synchro housing. They look very similar, apart from the ID of the hole where the idler bearing goes, easily remedied by using the correct bearing size.
Aside from that difference, can I use the 4 synchro housing on my 3 synchro box?
Thanks!
Morbo
PostPosted: Tue Sep 06, 2022 5:35 pm
Yes. I have done it. But check that the housing will fit over the outrigger bearing with both dowels fitted.
Dowel position varied a little over the years, I remember having to leave the lower dowel out on 2 boxes in my time. These parts were made before CNC machining was a thing.
PostPosted: Tue Sep 06, 2022 7:53 pm
Thanks doc, much appreciated.
I'll check alignment
