It is currently Sat Jul 19, 2025 2:02 am
 Post subject: AYG0175 29D Distributor
PostPosted: Thu Sep 29, 2022 4:36 pm
Just wondering where I can get replacement advance springs for the above distributor.
Also what grease is used internally.
PostPosted: Thu Sep 29, 2022 5:19 pm
Some details are in an old post:
viewtopic.php?f=2&t=63023&hilit=factory+cooper+S+distributor+advance+curve&start=0
The original springset for Mk2, according to winabbey's research, is Lucas 62411108.
PostPosted: Thu Sep 29, 2022 6:35 pm
Thanks Bill B. Have done a Google search and come up with nothing.
PostPosted: Fri Sep 30, 2022 7:29 am
Given the lack of spares and the high price of that which is available for 29D's would you be better off with a different model?
Cheers Dave.
PostPosted: Fri Sep 30, 2022 8:26 am
The springs should be interchangeable with the 25D, and you can use nearly any brand of distributor springs as long as they give the right curve
You might be better off to get a custom curve put in your distributor to match todays fuel and the spec of your engine. Even brand new, the Cooper S was reported to have pinking and the manual asked you to change the base timing pending on the fuel you used
PostPosted: Fri Sep 30, 2022 8:40 am
http://www.distributordoctor.com/distri ... rings.html
PostPosted: Fri Sep 30, 2022 8:54 am
Being an Australian distributor 'distributor doctor' had nothing for me.
PostPosted: Fri Sep 30, 2022 9:03 am
Springs are springs, as long as they are the right length and strength
PostPosted: Fri Sep 30, 2022 9:09 am
So what is needed right spring dimensions for this distributor.
PostPosted: Fri Sep 30, 2022 9:12 am
You need the right springs for your engine and modern fuel. As mentioned above this might not be the same as from the factory
Any decent distributor shop can graph the curve and adjust it to be correct with the vast selection of springs they have
PostPosted: Fri Sep 30, 2022 7:48 pm
What are these dizzys worth ?
