It is currently Sun Jun 29, 2025 3:22 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Distributor Cover
PostPosted: Mon Oct 24, 2022 12:26 pm
GuamMini wrote:
I would like to buy the original cover that came with the GT if there is any out there.
In his post above cooperess says he has one available.
PostPosted: Mon Oct 24, 2022 2:01 pm
The proper 60/70s solution was a section of the side of a Foster’s tinny carton slid between the grill and the slam panel support. These used to have a bit of a waxy coveting making them resistant to water and quite durable.
Might be problematic is you have an oil cooler though. 8)
Cheers, Ian
PostPosted: Mon Oct 24, 2022 5:01 pm
Id buy one.
1973 Clubman GT - YG2S8 1637
PostPosted: Mon Oct 24, 2022 8:22 pm
GuamMini wrote:
Id buy one.
GuamMini, I will part with the Leyland distributor water shield, looking for $30 + postage.
PostPosted: Tue Oct 25, 2022 3:09 pm
ausdino wrote:
Hinesy1275 wrote:
HYL4234 needs modification to fit over an oil cooler - the above distributor cover suggestion is better suited with oil cooler fitment
I still have one from back in the day, never had problems that I can recall, running it on my old mk2 S in the late 70's. Will be using it (hopefully! depend on oldtimers and it fitting) on the car under resto.
I stand corrected - apologies. Assume it fits better with the shallower alternator for Mk2 & GT.
With the extra depth of the generator, the oil cooler hose runs closer to the distributor requiring a little more real estate, thereby encroaching on the lower 'tongue' of the shield.
PostPosted: Wed Oct 26, 2022 4:43 pm
PM me cost including shipping to 1402 Route 15 Mangilao, Guam 96913
PostPosted: Wed Oct 26, 2022 10:12 pm
PM sent
PostPosted: Wed Feb 08, 2023 11:16 am
I got the cover how does it attach to the distributor just hanging of the plug leads? Is there a clamp to the distributor body?
PostPosted: Wed Feb 08, 2023 12:49 pm
I believe it just sits over the distributor and held in place by gravity. But looking at the one you have pictured it appears to suit side entry plug leads to the dizzy whereas the correct 29D4 has top entry leads.
PostPosted: Fri Feb 10, 2023 9:31 am
This what I was sold and I asked if it was for the Clubman GT and true mine is a top entry cap.
PostPosted: Fri Feb 10, 2023 10:05 pm
I think it's pretty clear from the photo that it would not suit a top entry cap
It probably rains very heavily in Guam, being Tropical - I'd look at this type that were used on later UK minis, it attaches via the rocker cover top bolts and covers just about everything
https://www.minispares.com/product/Classic/BHM1675.aspx
