It is currently Sat Jul 19, 2025 3:27 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Fri Nov 18, 2022 11:39 am
cooperess wrote:
Is there any way to check if your clutch works with the engine out of the car? Tried to move rod by hand and it's a no go.
Time to invest in a new one.
PostPosted: Fri Nov 18, 2022 12:32 pm
Sorry, I don't understand.
I just want to test the clutch before installing the engine back into the car.
PostPosted: Fri Nov 18, 2022 12:57 pm
If the engine is out you can easily pop the cover off and have a look. Removing the flywheel and replacing the clutch plate is cheap and easy and a decent investment while the engine is out
If the clutch arm is at about 90degrees from the line of the plunger, then likely there is significant wear in the system (left side of the photo). At this point the slave cylinder simply doesn’t have enough travel to release the clutch
I replaced:
Clutch arm
Plunger
Throw out bearing
Clevis pins
And you can see the improved angle of the arm on the right side of the photo
PostPosted: Fri Nov 18, 2022 2:55 pm
All parts have been checked and replaced if necessary. I would like to have the clutch disengage with the motor out of the car.
PostPosted: Fri Nov 18, 2022 3:41 pm
In that case, get a long pipe/breaker bar and pull the clutch arm out until it releases
Or add the slave cylinder and use a pedal box to push the slave
PostPosted: Fri Nov 18, 2022 5:21 pm
Thanks Timmy, that worked.
Users browsing this forum: No registered users and 111 guests
