It is currently Sat Jul 19, 2025 3:14 am
PostPosted: Tue Nov 22, 2022 1:34 pm
When machining the working face of the clutch pressure plate I believe it is important to maintain the correct height between this face and the top of the mounting posts.
Can any one enlighten me as to this dimension and is there a tolerance applicable?
Enjoy your Mini
Regards
John Sneddon
PostPosted: Tue Nov 22, 2022 1:45 pm
Here's a link to the bit in my build thread that mentions machining the clutch pressure plate.
viewtopic.php?f=3&t=98057&p=1045320
PostPosted: Tue Nov 22, 2022 2:20 pm
By some chance Doug do any of your drawings show this dimension
Enjoy your Mini
Regards
John Sneddon
PostPosted: Tue Nov 22, 2022 2:49 pm
Sorry, no, being a UK part and not Australian.
PostPosted: Tue Nov 22, 2022 4:47 pm
I believe it is 25.0mm. that's what my local brakes and clutch shop has always machined mine to.
Bear in mind the flywheel face could have been machined in the past so it's important to check the assembled height. The spring should be flat or slightly less, when assembled with a new clutch driven plate.
So the pressure plate may need a little more taken off the 3 lugs if so.
PostPosted: Wed Nov 23, 2022 8:29 am
Came across this from Keith Calver for consideration. See last paragraph:
https://www.calverst.com/technical-info ... alignment/
Basically 1inch, as drmini said.
