It is currently Fri Jul 18, 2025 4:18 pm
 Post subject: 1970 mini C.S dizzie
PostPosted: Sat May 19, 2018 8:07 pm
Hello All ,
Is it worthwhile fitting an electronic distributer ?What are the advantages ?Also what is the best type and supplier ?
TY Allen
 Post subject: Re: 1970 mini C.S dizzie
PostPosted: Sat May 19, 2018 8:16 pm
I have had my 29D rebuilt with a new bush and fitted with an Accuspark electronic ignition module. As a consequence I haven't had a need to look at the dizzy since 2013.
The removal of the points stops the dizzy shaft jumping around, so the timing will settle down if the bush is a little worn. I also fitted an Accuspark Blackbox at the time, so I have a high energy coil fitted as they can operate very low ohm coils. Another plus for cold Canberra starts in winter.
PostPosted: Sat May 19, 2018 8:25 pm
I dropped an Accuspark module into my 23D4 dissy - No problems at all.
PostPosted: Sat May 19, 2018 10:17 pm
you guys are much smarter than I .Is the 23D4 the same as on my CS 1970 also where can I get an Accuspark from ?
TY for your help
Allen
PostPosted: Sat May 19, 2018 10:21 pm
The same module is used on the 23D4, 25D4 and 29D4.
https://www.ebay.com.au/itm/Morris-Mini ... 23a1036dd1
PostPosted: Sun May 20, 2018 8:50 am
Any of the parts supplier will have them as they're widely fitted these days.
PostPosted: Sun May 20, 2018 3:47 pm
MinisPlus
https://www.minisplus.com.au/classic-mi ... ion-kit-uk
Minis Plus import these modules directly as such our pricing is very cometitive.
How can it be rusty when it's covered in so much oil?
PostPosted: Fri Nov 25, 2022 9:57 am
Can a Mk2 Cooper S 29D4 AYG0175 dizzy be replaced with a Mk1 electronic 23D4 dizzy with no complications?
PostPosted: Fri Nov 25, 2022 11:24 am
They are physically interchangeable. You will need the specific distributor cap (and plug leads if you are using a side entry cap)
You need to ensure the advance timing curve is appropriate for your engine
PostPosted: Fri Nov 25, 2022 6:32 pm
Hi, most people will not be aware of the fact that the advance curve changes if you fit an electronic ignition kit. some of the later electronic distributors tested fire two sparks up to 8 degrees apart, if they have an erratic advance curve. If your timing light shows the mark leaping around, you have a major problem. Cheers Lindsay Siebler
1959 Austin A40 Farina fun car
1965 Mk1 Cooper S restored
1970 Colt 1100F SS restored
2014 Mitsubishi Imiev fully electric daily driver
1948 Allard M coupe Olds 215 v8 project
1971 Twin cam Escort ex Uk championship winning rally car project
PostPosted: Fri Nov 25, 2022 8:13 pm
Sounds like I should steer clear of the electronic ignition kit. What about a complete electronic 23D4 distributor and fitting it in place of a 29D4 in a Mk2?
