It is currently Wed Aug 13, 2025 6:09 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sat Dec 31, 2022 10:17 am
A leak usually shows up as a drop in ride height fairly quickly. Best way to judge height is by looking at the car on a level surface.
You probably realise that a leak in a front displacer hose will fill up the hollow top where the hose is attached, so the leak won't appear on the outside or under the car for some time.
I don't think the colour of the fluid is much of an issue. Most of it will still be green, just with some rust colour added. 7 years isn't long and the factory never set a refill period, unlike the coolant or brake fluids.
You could try inserting a small screwdriver under the dust boot lower edge to see if there is any fluid building up from a leak in the flexible part of the displacer.
And try to avoid removing the dust boot from its large end. Very frustrating thing to pop back on!
PostPosted: Sat Dec 31, 2022 3:41 pm
Thanks Bill. I will investigate your suggestion of looking inside the boot. This has me stumped, for one who has rallied hydro Coopers and blown displacers before I am truely stumped.
Users browsing this forum: No registered users and 274 guests
