It is currently Fri Jul 18, 2025 11:13 am
PostPosted: Sat Jan 14, 2023 11:44 am
Firefirey wrote:
Thanks Cooperess for your reply.
gtogreen1969: Did they use the 4TR for factory assembly if the 8TR was not available at the time or was the 4TR fitted after assembly if the 8TR failed later in life and the 8TR was out of stock or no longer available on the local market?
I can only see the 8TR in brochures, roadtests or period photos for the MK2 S, Mini K, Clubman GT, Clubman Van. I checked my collection of MK2S photos and the unrestored cars have the 8TR as well. This subject had been discussed before and I got the impression that the factory fitted the 8TR and the 4TR was a replacement spare part. I cant confirm the 4TR was ever factory fitted.
John Smidt has a few good comments here - viewtopic.php?f=2&t=48686&p=583443
PostPosted: Sat Jan 14, 2023 11:48 am
Online
Steam wrote:
Not all 4tr units are the same, the original was a 3 terminal unit for use with 10 and 11ac alternators.
A redesigned 4tr with the part number 37527 was produced for the 15 and 16 ac series alternators. This is a 4 terminal device with the connections being the same as the 8tr. The 3 pin was adjustable, the 4 pin is not.
The 8tr was described as a thick film design.
Yes, confirming what you said in the post I mentioned earlier - viewtopic.php?f=2&t=101068
PostPosted: Sat Jan 14, 2023 11:56 am
Online
Lacking photos confirming factory fitment I can only go by the parts books for the round-nose and Clubman I posted earlier that list the 4TR - 37527.
PostPosted: Sat Jan 14, 2023 12:08 pm
Online
A couple more things I stumbled across that might be of interest.
Minisport list a 4TR but it only has three connectors, not four. I wonder if it's incorrectly listed, being the Jag type instead, or maybe the image is the wrong one.
https://minisport.com.au/4tr-alternator ... -regulator
Here's the BMC engineering drawing for the 8TR. Can't find the equivalent for the 4TR at the moment.
PostPosted: Sat Jan 14, 2023 1:03 pm
PostPosted: Sat Jan 14, 2023 1:07 pm
cooperess wrote:
Warning sticker points to it being a replacement
PostPosted: Sat Jan 14, 2023 1:24 pm
8TR at the bottom of photo is 6/71
PostPosted: Sat Jan 14, 2023 1:57 pm
I would like to know whether 'Steam' has any information on another 4TR (4 pin) control box with Lucas number 37586. It is listed with 37527,suggesting they are interchangeable.
https://www.bing.com/images/search?view ... ajaxserp=0
I bought a 37586 years ago in case I needed one and would like to know if it is useful.
PostPosted: Sat Jan 14, 2023 4:16 pm
Bill, I have no info on that model number however if the terminals are in the correct place it will work as it should.
I am using an aftermarket 2 pin regulator on a 15ac, as long as the field gets the correct voltage level with regard to battery charge level it will work.
The 3 pin 4tr will also work if wired correctly, the 4 pin was to acheive battery sensing.
Cheers Dave.
PostPosted: Fri Jan 27, 2023 1:03 pm
I replaced the 4TR Voltage Regulator with a 8TR Voltage Regulator after asking about the factory fitted unit.
Was very lucky to find one with the correct date period and in working condition.
Thanks to everyone who supplied information and details to make it happen.
PostPosted: Fri Jan 27, 2023 1:41 pm
Perfect result. ;-)
Cheers Dave.
PostPosted: Fri Jan 27, 2023 6:59 pm
Thanks Steam.
From my checking online, it seems that the 4TR (black plastic box with 4 terminals) was used in various Triumph and MG models that used the early UK made 15AC alternator; 8TR was made in Australia to go with the Australian-made 15AC alternator used in mini K, Mk2 S and later models running alternators without internal control units.
So some parts for these units might be available for this combination through Triumph and MG specialists in UK and Nth America.
Users browsing this forum: Bing [Bot] and 97 guests
