It is currently Tue Aug 12, 2025 10:23 pm
 Post subject: 2 piece head lining
PostPosted: Fri Feb 17, 2023 4:42 pm
Hi all,
I have a 4th Q 1964 850, i am trying to work out if this should have a 2 piece roof lining or if they were changed over to single piece by then..
Thank you
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
 Post subject: Re: 2 piece head lining
PostPosted: Fri Feb 17, 2023 6:07 pm
They changed late in 1964. The changeover point was very similar to the Aussie boot lid with the narrower licence plate
850 number 51216
viewtopic.php?p=1064372#p1064372
PostPosted: Fri Feb 17, 2023 6:17 pm
I have a June/July '64 build, purchased new November '64. I'm the second owner. It has two piece hood lining and Aussie number plate.
PostPosted: Fri Feb 17, 2023 6:25 pm
Thanks guys.
I assume a 2 piece wouldn't correctly fit the later style?
mine is body #57xxx
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Fri Feb 17, 2023 6:46 pm
If it is a one piece there will be hood bow holes and extra brackets on a A and B posts for roof lining to tuck under 2 peice has none of that
PostPosted: Fri Feb 17, 2023 6:52 pm
In July 1964 at YMA2S1 51216 the two piece headlining was changed to the hood and single piece lining. Detailed on page 56 of my book.
Enjoy your Mini
Regards
John Sneddon
PostPosted: Fri Feb 17, 2023 7:18 pm
Thanks mate, where i do get a copy?
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Fri Feb 17, 2023 8:08 pm
Currently listed onEbay https://www.ebay.com.au/itm/265724384322
Enjoy your Mini
Regards
John Sneddon
PostPosted: Sat Feb 18, 2023 12:05 pm
Thanks mate, Mine currently has a single piece roof lining installed so i am unable to see what is above it. I like the look of the 2 piece roof lining.
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Sun Feb 26, 2023 12:51 pm
MINIRO wrote:
Thanks guys.
mine is body #57xxx
Hey all, just following up on the above question... Will the earlier 2 piece fit into a later roof aperture without issues?
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Sun Feb 26, 2023 4:52 pm
I would think so. Don't forget you will need the 2 piece metal frame as well. And the 2 piece doesn't have holes in the can't rail that I believe the one piece does to secure the metal support rods...
Cheers, Ian
PostPosted: Mon Feb 27, 2023 5:01 pm
I believe the 2 piece frames are very hard to come by, so if you know where you can get one, I’d be nailing their feet down quick.
PostPosted: Mon Feb 27, 2023 7:52 pm
I'm almost certain there was no change to the Mini turret and cant rails during the changeover to one piece headlining so a two piece should fit OK, provided any required fixing points or holes, if any, are there. Others may know how the earlier two-piece is fixed in place.
PostPosted: Mon Feb 27, 2023 8:24 pm
Just had a look at my 63 Cooper to compare.
It appears the only difference to be the lack of drilled holes in which to fit the hood bows. If you need I can look at another I have tomorrow to check if required.
A word of warning if you are planning to drill holes and fit the alter model. The positioning of the holes is critical to ensure that the hood lining will pull taught. Recently found that the spacing on some cars vary from others and hood lining will not fit as required particularly towards the back window.
Enjoy your Mini
Regards
John Sneddon
PostPosted: Mon Feb 27, 2023 9:00 pm
Each of the two piece frames has an outer perimeter and cross pieces. They just sit (tightly) on top of the cant rails. You hold each piece towards the middle, bow the centre rod downwards and then slide each piece forward or backwards as applicable. When you release the bow, spring tension holds it all in place.
Although, I have seen cars with a small Phillips head screw though the rear corners of the front piece into the cant rail.
Cheers, Ian
Users browsing this forum: Andosoft and 217 guests
