It is currently Fri Jul 18, 2025 8:39 pm
 Post subject: Outer CV joint Boots.
PostPosted: Wed Mar 29, 2023 12:58 pm
Good afternoon all
It would seem I need to replace the outer CV joint boots.
Is there a superior product or are the original style the better product. I have seen the super stretchy ones which I assume are a silicone boot or is there a type which is better than others.
What are everyones experiences?
Cheers.
Cheers Dave.
PostPosted: Wed Mar 29, 2023 1:02 pm
I have just installed the Japanese made ones after ones from minisport UK lasted less than 2000km. I expect all the other non Japanese ones will be just as bad.
The Japanese ones look and feel good but I wouldn't use the included ties.
Test... Don't Guess
PostPosted: Wed Mar 29, 2023 3:52 pm
Can I ask where the old (new!) ones failed. These ones are about 2000km old as well butI am trying to remember whether I fitted new ones or used a good old set.
Also a part no and supplier for your new ones.
Thanks & cheers.
Cheers Dave.
PostPosted: Wed Mar 29, 2023 5:56 pm
Thanks & cheers.
This is the failed minisport UK one. The section which goes onto the drive shaft broke off.
The Japanese ones are RGV2019 purchased from David Ainley (https://classicminisjapan.com/products/ ... int-boots/) They only fit disc brakes.
Test... Don't Guess
PostPosted: Wed Mar 29, 2023 6:25 pm
Many thanks.
Mine have a small split at the top of one of the peaks in the rubber. About an inch long on each one. It can hardly be seen, I only realised there was a problem because there was grease on the bottom arm.
Cheers Dave.
PostPosted: Wed Mar 29, 2023 11:45 pm
Hi Guys,
Search for boots made by F.Boge in Germany- you will find local suppliers if you do a google search
these are what I use on my Polaris ATV on the farm they are so stretchy that ...with the right tools, you can pull the small end over the CV Joint, they are multifit size {you can cut them down} in three different steps = they will fit Cooper S CV Joints- they are not cheap but they last and last
PostPosted: Thu Mar 30, 2023 2:51 pm
MAXRACER72 wrote:
Hi Guys,
Another option I had thought of is the Wurth ones which seem like the same idea as F.Boge ones and could even be the same, I just can't find a good picture of an F.Boge one.
Test... Don't Guess
PostPosted: Fri Mar 31, 2023 11:09 am
We have excellent quality boots for disc brake cars.
PostPosted: Fri Mar 31, 2023 12:45 pm
Could you link the product you have please.
Cheers.
Cheers Dave.
PostPosted: Fri Mar 31, 2023 1:45 pm
Cheers.
Karcraft don't have a shop website. You need to phone or email them to discuss your needs and to order. Don't be put off by this as they stock quality parts at good prices, and are the go-to supplier for many Mini enthusiasts.
You'll see on their website you can request the latest Mini parts price list via email.
http://www.karcraft.com.au/
PostPosted: Fri Mar 31, 2023 5:45 pm
If they had a website to buy online they would just about wipe out the competition, their prices are just so good.
PostPosted: Mon Apr 03, 2023 8:27 pm
IMAGE ATTACHED.
PostPosted: Sun Apr 16, 2023 11:53 am
Just for information I went wirh generic universal super stretch boot kits which work very well, are easy to fit and seem good quality. Came with good clamps/ties and a satchet of grease.
Cheers Dave.
Users browsing this forum: miniimports, Phil 850 and 83 guests
