It is currently Fri Jul 18, 2025 10:55 pm
PostPosted: Sun Apr 16, 2023 6:55 pm
cooperess wrote:
When you say the internals were different, do you mean the gears or the physical casting?
Gears are different. They used the same case
The MK2 S laygear is 22G1040. First motion shaft 22G1371 has 18 teeth and also has an "S" stamped into the spigot bearing end of the shaft but can't be seen while the box is assembled. Diff ratio is 3.44 (18 tooth pinion, 62 tooth crown wheel).
The Mini K and Clubman laygear is 22G927. First motion shaft 22G1093 has 17 teeth. Final drive Diff ratio of 3.765 (17 tooth pinion, 64 tooth crown wheel) or 3.65 (17 tooth pinion, 62 tooth crown wheel)
PostPosted: Tue Apr 18, 2023 7:14 pm
i have amotor here with the casting numbers 12a 497 then the casting stamp just wondering if anyone knows what size it is
PostPosted: Tue Apr 18, 2023 7:21 pm
It's a 998 or 1098 block
PostPosted: Tue Apr 18, 2023 7:32 pm
thanks for the reply timmy
