It is currently Fri Jul 18, 2025 3:12 pm
PostPosted: Tue Apr 18, 2023 9:40 pm
My suspension seems like it may be too hard as I seem to feel heaps of bumps very sharply and it feels unstable cornering quickly. The only other mini I have driven was hydro so I don't know what it should be like. Tyres are 12" A539 and the total toe in on the rear is around 30′ (can't remember exactly).
I am wondering if it is the fact that the rubber cones were purchased in 2018 and unused until 2022? They were also purchased from a place which I have found everything from them has had to be replaced.
I got it registered in May 2022 and drove it for a few months before removing the engine and I didn't notice it but there were many more important issues to fix. It might have also been hidden a bit by the fact the subframe mounting bushes were new but rubbish and I also replaced them before reinstalling the engine.
Test... Don't Guess
PostPosted: Wed Apr 19, 2023 6:48 pm
do you know what brand they are ?? will help alot
PostPosted: Wed Apr 19, 2023 9:06 pm
Not sure but they would've been the cheapest ones minisport uk sold, it wasn't my project at that stage and all parts were purchased from them.
I guess these ones unless they have changed what they sell.
Test... Don't Guess
PostPosted: Thu Apr 20, 2023 9:08 am
I might try lowering the tyre pressure, I am currently running 32psi front, 30psi rear.
Test... Don't Guess
PostPosted: Thu Apr 20, 2023 12:59 pm
I used to run 30/28 I now run 28/26. I think grip is better in both wet and dry.
165/70-10 A008s.
PostPosted: Thu Apr 20, 2023 1:52 pm
You may have one that has collapsed, giving uneven loading across the car. A bit like an uneven table at your local cafe!
PostPosted: Thu Apr 20, 2023 6:00 pm
if they are a cheap set they will not last. I use a Moulton kit and they have not gone down at all and are very comfy
PostPosted: Thu Apr 20, 2023 6:24 pm
How high is the suspension? If it’s too low and hitting the bumpstops it’ll cause irregular handling
PostPosted: Thu Apr 20, 2023 7:14 pm
Wheel centre to arch:
Front: 30cm
Rear: 34cm
Now that I have remeasured it the front is a bit low. The only offficial data I have found is for hydro minis and specifies 33cm for the front. I can't remember what I set it to originally but I seem to recall 34cm and the rear was higher. I still wouldn't call this low, I even constantly get told by one person that I have "beach buggy suspension" :D
This is the quickest data I have on hand, when I adjusted it I used what is in an official workshop manual pdf that I have.
Test... Don't Guess
PostPosted: Thu Apr 20, 2023 9:42 pm
165/70-10 A008s.
I will try that tomorrow and see if it improves anything.
Test... Don't Guess
PostPosted: Fri Apr 21, 2023 3:04 pm
If you have adjustable height then the HiLos may be the culprit.
"Sports" hilos are flat - no radius at all.
The greater the curve, the softer the suspension.
Cleverly made ones (calling Matt Read) have a progressive rating/curve.
PostPosted: Fri Apr 21, 2023 3:55 pm
I only have hilos on the front and they are original ripspeed ones, the type which use the hex rod to adjust. These should be ok right?
If I get stuck on this problem I will go confuse Matt again, I have confused him many times although I don't expect this would :lol:
Test... Don't Guess
PostPosted: Wed May 03, 2023 12:05 pm
I haven't yet raised the front and realigned it but the tyre pressures do seem to have made a big difference.
On another issue what would the acceptable runout be on a 12" steel wheel. When I balanced them they did "wobble" around which I think might be causing some noise I am getting. I have three more to choose from, I just need to repaint them.
Test... Don't Guess
Users browsing this forum: No registered users and 112 guests
