It is currently Wed Jun 25, 2025 3:05 pm
PostPosted: Mon May 22, 2023 2:01 pm
The indicator cancelation screw on a mk1 steering column, where should this clock?
My steering wheel is not sitting where it should be, so I would like to remove and replace the column, but making sure it is correctly clocked.
Thank you
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Mon May 22, 2023 2:08 pm
The column can only go on one way on most minis. In the central/straight position the clamping bolt should be horizontal at the bottom. The steering wheel should be level in this position.
Too many minis
PostPosted: Mon May 22, 2023 2:50 pm
Thank you. I haven't pulled a column on a mk1 before. So this is good info to know.
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Mon May 22, 2023 3:02 pm
As mentioned above, pinch bolt horizontal
Then make sure the wheel is on straight
Then line up the outer column so that the cancelling peg on the column lines up with the centre of the indicator stalk.
PostPosted: Mon May 22, 2023 9:51 pm
If the steering wheel is not on straight then maybe it needs to removed from the column and corrected??
No need to move the column unless there is another problem.
Cheers, Ian
Users browsing this forum: winabbey and 123 guests
