It is currently Sat Jul 19, 2025 12:04 pm
PostPosted: Tue Jun 13, 2023 8:54 am
Hi do I replace the rack or rebuild the rack? Comments. It rattles a lot. Can I remove and replace it without entirely dropping the subframe to the ground?
1973 Clubman GT - YG2S8 1637
PostPosted: Tue Jun 13, 2023 11:37 am
Best to rebuild, the new racks are apparently rubbish. It can be changed eithout dropping the subframe entirely.
Is it definitely the rack at fault?
Test... Don't Guess
PostPosted: Tue Jun 13, 2023 1:14 pm
Yes clunks when hitting a bump or releasing the clutch moving forward. If I were to get it out I will need to lower the subframe right? What are the parts I will need to rebuild are there any machining required?
Thanks
PostPosted: Tue Jun 13, 2023 1:41 pm
It depends on what rack you have. Australian minis had locally sourced racks, but yours could have been changed in the last 50 years
Some can be rebuilt and some can’t
I’d start by checking the u bolts are tight under the carpet and then try and diagnose the source of the noise before you take out the rack
PostPosted: Tue Jun 13, 2023 8:22 pm
I am not sure your problem is the rack.
Since my one is a Rover I was able to just lower the rear of the subframe just enough to remove it but since yours is an earlier subframe it probably needs to be dropped straight down (not all the way). You will need to disconnect the exhaust, engine steadies and brake line. Everything else should be ok.
There is no machining required. This gives you an idea of the process https://www.theminiforum.co.uk/forums/topic/322176-steering-rack-overhaul-uk-type-mkii/
Test... Don't Guess
PostPosted: Tue Jun 13, 2023 10:28 pm
If you a certain you want to do the rack, I would try and source a reconditioned Aussie one from one of the Australian Mini suppliers.
PostPosted: Wed Jun 14, 2023 7:54 am
Matt Read in Brisbane has reconditioned Aussie AYA6001 racks.
PostPosted: Wed Jun 14, 2023 9:14 am
They are inexpensive new but probably made in China
PostPosted: Wed Jun 14, 2023 9:20 am
It is better to buy a reconditioned one I hope they will ship to Guam
PostPosted: Wed Jun 14, 2023 9:21 am
How can I reach him?
PostPosted: Wed Jun 14, 2023 9:50 am
ReadSpeed Mini Mecca & The Mini Man
Shed 5L, 167 East,
Murarrie Road,
MURARRIE, QLD, 4172
Tel: (07) 3399 9999
Mob: 0407 135 656
https://www.facebook.com/profile.php?id ... tid=LQQJ4d
PostPosted: Wed Jun 14, 2023 10:39 am
Shed 5L, 167 East,
Murarrie Road,
MURARRIE, QLD, 4172
Tel: (07) 3399 9999
Mob: 0407 135 656
Thank you I sent them a message on Facebook
PostPosted: Wed Jun 14, 2023 4:28 pm
GuamMini wrote:
Shed 5L, 167 East,
Murarrie Road,
MURARRIE, QLD, 4172
Tel: (07) 3399 9999
Mob: 0407 135 656
unfortunately he much prefers that people call him, he says he often misses messages on Facebook and text
Test... Don't Guess
PostPosted: Mon Jun 26, 2023 10:23 am
He messaged me on FB but after I said I would need the rack for Guam he never responded back. I guess that means a no
PostPosted: Mon Jun 26, 2023 1:01 pm
I am not sure about that. I would expect that Matt would send one anywhere in order to help someone. I have no idea if he usually sends internationally but he does try to help everyone. He often posts online looking for who he was supposed to send stuff to etc as he loses track of messages and details.
If it comes to it I could get one and send it to you, I work nearby to him.
Test... Don't Guess
