It is currently Fri Jul 18, 2025 5:38 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jul 05, 2023 6:29 pm
winabbey wrote:
It's position may be shown on the pedal box drawing.
Indeed the position of the bracket part AYA5162 is shown on the pedal box assembly drawing AYA5160.
It is positioned partly across one of the 1 5/8" diameter holes in the side of the box and arc welded along the two edges that are not in mid-air in the hole (welding signified by the row of x'es).
Click to enlarge the image, and again to enlarge further.
PostPosted: Wed Jul 05, 2023 6:49 pm
I don't remember the big hole in the way of mounting it, but my home made bracket is bigger. I'll try and get a pic tomorrow.
PostPosted: Wed Jul 05, 2023 7:47 pm
I fitted a standard replacement brake switch above the brake pedal. The switch is OFF when depressed and ON when the brake pedal moves down (the opposite of a normal switch). The switch is large and needed a large angled bracket and solid bolts. I used a right angled drill holder to drill the mounting holes; it took hours, upside down under the steering wheel. As the switch only carries about 20mA to switch on the relay I should have used a much smaller lever switch which would have been much easier to mount.
Dave D
