It is currently Wed Jul 16, 2025 4:43 am
 Post subject: Radiator
PostPosted: Mon Aug 21, 2023 4:32 pm
Do the factory fitted radiators have any id tag on them? If they did what were the letters and numbers please.
71 MKII Cooper S
 Post subject: Re: Radiator
PostPosted: Mon Aug 21, 2023 4:44 pm
Early tags were on top and later were on the side near the filler neck
L66 = Dec 1966
K72 = Nov 1972
PostPosted: Mon Aug 21, 2023 5:15 pm
This is the radiator in my late 1970 MK II S with the Newcell plate on the side of the header tank. The part number is AYA2077. I'm very confident your 1971 S would be the same.
The last of the round-nose parts books shows different parts for different models of Mini. The Cooper S is listed as AYA2077.
Someone, I think on this forum, had the brass plate remade as theirs was lost (pic below). Maybe do a search or perhaps the member sees this and will comment.
PostPosted: Mon Aug 21, 2023 5:22 pm
This is it - viewtopic.php?f=2&t=101110
PostPosted: Sat Aug 26, 2023 6:09 am
Hey Doug, I have heard the Cooper S had more fins per inch than normal ones. But I don't ever remember seeing any difference between radiators (apart from the tanks themselves)'
What do you know about what makes them difference to what was fitted to the mini K for example.
PostPosted: Sat Aug 26, 2023 8:46 am
16 gills per inch from memory.
