It is currently Sun Jun 29, 2025 9:04 pm
 Post subject: EVAPO RUST
PostPosted: Fri Dec 29, 2023 7:54 am
Please give your experience on using CRC EVAPO RUST on rusty Mini's.
It sounds good and looks good on youtube.
 Post subject: Re: EVAPO RUST
PostPosted: Wed Jan 03, 2024 9:14 pm
The MSDS says its just phosphoric acid (10-20%) in water, with some other additives - all rust converters are basically the same thing, it's the phosphoric acid that does the work.
A very nice man once gave me a couple of bottles of basically 100%, I use it when I have no other way of dealing with rust, and only ever a little bit - wire brush, wipe on, wipe off
PostPosted: Thu Jan 04, 2024 8:29 pm
Ed China did a YT video soaking a range rover chassis in nearly 2000 litres of it.
Mk 1 Cooper S 1965
If you could erase all your mistakes of the past
You would also erase the wisdom of your present
Remember the lesson not the disappointment.
PostPosted: Fri Jan 05, 2024 10:10 am
Phosphoric acid will remove rust from steel/iron but converters change the rust to a protective layer which limits further rusting.
Emery Chemicals in Sydney used to make "Emertan" which was a tannic acid based rust converter. Had a magnificent port wine smell too. "Fertan" is a similar tannic acid converter that is still available.
Users browsing this forum: Phil 850 and 82 guests
