It is currently Mon Jul 14, 2025 12:26 pm
 Post subject: 1275 head gasket
PostPosted: Tue Apr 09, 2024 4:02 pm
1275 head gasket what are people using now a friend has had one fail after a couple of months and not many klms done unfortunately I don't know which one the used
 Post subject: Re: 1275 head gasket
PostPosted: Tue Apr 09, 2024 6:21 pm
Payen AF470
Retighten when hot and again after 1000km or so.
PostPosted: Tue Apr 09, 2024 6:53 pm
Payen AF470
Thank you will pass the information on
PostPosted: Tue Apr 09, 2024 7:16 pm
I would suggest finding out why it failed once apart. He may have further issues.
Cheers Dave.
PostPosted: Wed Apr 10, 2024 12:04 pm
I'm nots sure what happened was put in a mechani head was redone by a reputable person reco carb block deck checked
PostPosted: Wed Apr 10, 2024 1:54 pm
If the timing is out it can cause head gsket issues, and the new chinese distributors are prone to wild timing variations.
Cheers Dave.
PostPosted: Wed Apr 10, 2024 4:12 pm
unfortunately reputable doesn't mean much. There's one here who can't check dwell at all or even do timing correctly but rebuilds mini engines for people.
Since the block and head was supposedly checked then the gasket itself is unlikely to be at fault.
Too many minis
