It is currently Tue Jun 24, 2025 12:18 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: LED upgrade - Mini K
PostPosted: Thu Aug 08, 2024 1:04 pm
winabbey wrote:
Hopefully someone will have a pic of the setup on a later Leyland Mini you could copy.
Here are a few pics
PostPosted: Thu Aug 08, 2024 3:27 pm
Great pics gtogreen1969 ! Very useful.
Also found this TMF article, where the guy made a bracket and used grub screws to hold it in place.
https://www.theminiforum.co.uk/forums/t ... t-76-type/
PostPosted: Thu Aug 08, 2024 3:51 pm
Here are some others which were modded but they drilled 2 holes in the pedal box for the bracket
PostPosted: Thu Aug 08, 2024 4:14 pm
When I converted one I just used a switch from SCA. I just chose one which had two nuts so that it had adjustment, looks like it would've been TBS072. I modified the bracket someone had already installed though. They had used a micro switch which is physically and electrically unsuitable.
Too many minis
PostPosted: Thu Aug 08, 2024 9:09 pm
Search FAM4370
Brake switch Bracket
PostPosted: Thu Aug 08, 2024 9:25 pm
I added a mechanical brake switch to my Mini about 7 years ago and it has worked perfectly every since.
It was a "standard" replacement brake switch from an automotive parts retailer but I can't remember which one. I still have the kinked neck and ringing in the ears from drilling a mounting hole in the pedal bracket frame in situ.
The switch MUST be a "normally closed" switch, so that when the plunger is pushed in (the normal position when the brake pedal is up) the contacts are open; ie the brake lights are OFF. When you push down on the brake pedal the plunger pushes out and the contacts close; turning on the brake lights. (Most push button switches work the other way around. They are "normally open". They are off when the plunger is out, and on when the plunger is in.)
(I used the mechanical switch wired in parallel with the old hydraulic switch to activate a relay to power the brake and high centre brake light on the parcel shelf. This works for me but adds more complexity and wiring leads through the bulkhead.)
Dave D
PostPosted: Fri Aug 09, 2024 10:46 am
Isn't the clutch pedal AYA5067?
PostPosted: Fri Aug 09, 2024 5:28 pm
Yep
