It is currently Mon Jun 23, 2025 12:29 am
PostPosted: Mon Dec 23, 2024 3:12 pm
Is there a difference in the cover of a single to a twin row timing chain or are the covers the same?
Cheers Dave.
PostPosted: Tue Dec 24, 2024 7:44 am
There are several cover designs. Some have a brace across the middle which needs ro be ground away, I would avoid these.
Don't use the single row chain oil slinger it's too wide.
Either fit the almost flat 1275 one, or run without. I'm not convinced they do much with current oil seals. And new ones now are too soft and can compress and loosen the harmonic balancer.
Edit:
For example my 1360 runs the Italian 'Triger' belt drive kit, which have no slinger.
PostPosted: Wed Dec 25, 2024 6:39 am
Thanks doc, great info. Although I actually meant is there a way of telling if an engine has a duplex chain from the cover.
Cheers Dave.
Cheers Dave.
PostPosted: Wed Dec 25, 2024 7:00 am
You can’t tell without removing the cover or crank pulley. Most covers will work for either setup & most minis have had at least one new timing chain set by now
Users browsing this forum: No registered users and 132 guests
