It is currently Fri Jul 18, 2025 1:52 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jul 12, 2004 10:47 pm
I think it's an optical illusion. Both shoes seem level with the outside of the wheel cylinder and look square to me.
Those linings look awful rough though- worn drum?
Best cure for drum brake probs- machine the drums at a brake place, get new O/S bonded shoes to suit, and new wheel cylinders. Pretty cheap, and results guaranteed. :wink:
PostPosted: Mon Jul 12, 2004 11:29 pm
doc...i'm pretty sure thats a rubber o-ring i can see poking out there!
cush...they're easy as to change....just a cirlip on the back of the drum backing plate and then you pull it out...easy! last time i got a set of wheel cylinders it cost me $80 for the pair (rears, which by the look of it is what is in your pic)
ps. the brake in the pic is already single leading shoe...twin leading shoe drums have two wheel cylinders in each wheel
PostPosted: Tue Jul 13, 2004 9:07 am
two tips i can give regarding changing the Drum brakes
1 Do one side at a time so you have the other to refer to.
2 When replacing the springs (which can be a pain) Use a flat head screw driver not pliers. Place on end on and place the flat head in a couple of winds in the other end.
Also get the drums checked if they have been machine before. Also get a freind to help you bleed the brakes
Also dont get the riverted Shoes but the bonded shoes
happy braking Chushy
PostPosted: Tue Jul 13, 2004 10:18 am
Christoph... bargain... if i can't get it back in with a screw driver i'll get it fixed with my wallet.
drmini: yeah, they are worn, i cleared out about a centimetre pile of brake dust from the drum so it looks nice now... better than the other side which has a nice matching ridge on the shoe and ditch on the drum... *shakes mini 8 ball* ....."machining looks likely"
thommo : thanks...i figured it'd be easy.. :) and they're my fronts... and yeah... i figured they'd be single leading shoes....coz it makes the pricey disc conversion a better idea... :cry:
gaf: thanks for the tips, dude.. ( my nickname is getting longer each day. ;) )
i think that's everyone :)
PostPosted: Tue Jul 13, 2004 11:39 am
I just bought two 5/8 rear cyls for when i finally install S discs on the front. They are brand new (not reco) and cost $25 each from Classic Motoring in Canberra, A.C.T.
PostPosted: Tue Jul 13, 2004 11:47 am
good idea.. i might start buying stuff now and stockpile it ...it may cost more in the long run but it won't seem like it... :)
PostPosted: Tue Jul 13, 2004 7:40 pm
Sorry for the additional H mate. :oops:
Check to see if the drums have been machined. If they have been by the Cooper S drums and your wheels will poke out a little for the back and will match with the disc front end
Have fun Tushy. ... I think that the one that will stay :D
Users browsing this forum: No registered users and 114 guests
