It is currently Thu Jul 31, 2025 2:11 pm
 Post subject: Crap!!!! I smell Fuel!
PostPosted: Sat Jun 18, 2005 5:54 pm
Gee! Havent drivin Cheezel all week lets see if she wants to start!!! Whirr Whirr then mini type putting noises all good here :shock: Gee fuel smells really strong choke not out to much push it back in getting worse! Better investigate as fuel is pissing out of Goss Fuel pump. Should I rebuild it or replace it!!! Any suggestions! Book says can get re build kits wondering if they still exist. Any suggestions guys! From looks of things is original Pump still :cry: :cry: :cry:
PostPosted: Sat Jun 18, 2005 6:08 pm
I put a rebuild kit through my pump last year. Got the kit from Repco. It was about $35 from memory (may have been more?)
They are a good pump but they are 40 years old!
Mine was leaking from the diaphram but they can leak from the top.
PostPosted: Sat Jun 18, 2005 10:29 pm
I priced the rebuil kit at $34 at a local spares place, and then realised mine was a sealed unit so i bought a new pump for $80 bucks i think it was.
It just depends on how much time you have to muck around, they arnt that complicated to rebuild. Getting the nuts done up whilst the motor was still in the car took forever, a ratchet spanner would of been nice.
Ryan
PostPosted: Sat Jun 18, 2005 10:45 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
disconect the fuel line buy a lectric pump and away you go
makka
PostPosted: Sat Jun 18, 2005 11:50 pm
Yep...gotta agree there, if your fuel pump needs new bits and pieces, turf it and get an electric one. Works great :D
Rod Image
PostPosted: Sun Jun 19, 2005 12:48 am
My vote is for electric too! I am having starting problems lately, not bad but slightly. It would start everytime without fail if I have an electric pump...
PostPosted: Sun Jun 19, 2005 8:15 am
I fitted the Facet/Purolator/TRW electronic ones. Barney runs an SU, Ha-Ha a Dellorto. No pressure regulator. No probs with either. Ha-Ha's is well over 10 years old now.
They are a bit noisy- I mounted Barney's on a Mini square exhaust mount to shut it up. Can't hear it with motor running.... :D
PostPosted: Sun Jun 19, 2005 8:20 am
I have a New Old stock Mech fuel Pump doing nothing if someone wants it $50
I have also fitted Morris electric fuel pump on the Rear seat area...atleast sue knopws when she's out of fuel :wink:
PostPosted: Sun Jun 19, 2005 10:18 am
Thanks all. :D Think I will try a rebuild first then electric if not happy!!!
 Post subject: More Trouble!!!!
PostPosted: Fri Jun 24, 2005 6:17 pm
Have rebuilt pump! Drove to Work other day no probs then went to drive to the meeting thursday night and she commenced smoking when pulling up at lights!!! Lots of smoke not good. When idling is crap sounds like is flooding out obviously due to amount of fuel being delivered. What do I do, short of putting in electric pump!!! :roll:
 Post subject: Re: More Trouble!!!!
PostPosted: Fri Jun 24, 2005 6:25 pm
How will fitting an electric pump fix it?
Check the carby. It could be the float level or the needle and seat in the float bowl.
PostPosted: Fri Jun 24, 2005 6:27 pm
Has been suggested to me that an electric pump can regulte pressure? Think thats crap personally! Maybe I'm just to traditional.
PostPosted: Fri Jun 24, 2005 8:16 pm
The pressure with a mechanical pump is fixed, it's set by the return spring inside. Can't change. Would be fine for SU carbs.
Are you sure it's not the carb flooding? A new needle valve & seat will fix it if so.
:wink:
PostPosted: Sat Jun 25, 2005 4:52 pm
Thanks will check it 2moro. Too late to do it today! :)
