It is currently Tue Jul 22, 2025 11:57 pm
 Post subject: Damn O ring :-x
PostPosted: Sat Jun 18, 2005 10:22 pm
Bolted my motor to the box the other night.
The good Doc popped in today for a check up.......said "Did you fit that O ring...."
I said "what O ring Doc?"
He said "That one right there in your gasket set pack!:
:shock: :evil: :x
Had to seperate the motor and box tonight and fit the damn thing!!! :x
Wasn't too hard though.
Cheers Kev for timing the cam. :wink:
She's comin' together! :wink:
PostPosted: Sat Jun 18, 2005 10:23 pm
wats an o ring and where does it go anton
Inconspicuously Conspicuous
PostPosted: Sat Jun 18, 2005 10:24 pm
black round rubber ring
this one seals the oil flow tube in the top of the gearbox housing.
No fit - big leak :x
PostPosted: Sat Jun 18, 2005 10:27 pm
ah that BIG hole on the side :shock:
PostPosted: Sat Jun 18, 2005 10:31 pm
yea....that'd be it :wink:
You live and learn....
None of my 5 manuals mentioned anything about it!! :x That sux!
PostPosted: Sat Jun 18, 2005 10:39 pm
:wink: Once you have forgoten it you want again
Did you fit ...block on the ground and flip the box ontop...Much easier :wink:
PostPosted: Sat Jun 18, 2005 10:42 pm
yea we flipped it all over so box is up in the air. It was no big deal to undo the bolts and lift off the box then back on.
PostPosted: Sat Jun 18, 2005 10:54 pm
:wink:
PostPosted: Sat Jun 18, 2005 11:05 pm
i thought this was going to be a NASA thread! :wink:
PostPosted: Sun Jun 19, 2005 7:50 am
not true if you dont fit it you get a big leak. if you dont fit it you get no oil pressure as the pump cant suck the oil up.
bet you wont forget it again.
PostPosted: Sun Jun 19, 2005 7:56 am
I did the same thing when I build the 1310 in GT... pain in the ass.. stupid books.. :evil:
PostPosted: Sun Jun 19, 2005 7:57 am
Yeah Jai, that's what I told him.
Better to find it now than later, in the car!! :lol: :cry:
PostPosted: Sun Jun 19, 2005 8:22 am
oh yea....no oil pressure.....thats right..... :oops: you did say that.
But.....no oil pressure 'could' lead to a piston through the block.....then it would be a big oil leak!!! :lol:
PostPosted: Sun Jun 19, 2005 8:53 am
That and putting the thrust washers in back to front seem to be the common "oops i sure made a mess of that" mistakes. I must remember to do the same.
Aaron
