It is currently Tue Jul 22, 2025 3:45 am
 Post subject: Battery Question...
PostPosted: Mon Jun 20, 2005 3:34 pm
Since I have had the yellow leyland I have been plagued by alternator and battery problems. When I received the car the battery was in the negative earth position (negative terminal to earth) and there it has stayed.
The other night when putting the battery back in, I put it in the wrong way. When I went to connect it up I had connected the positive to the earth and was hooking the negative when there was a large flash. I realised what I had done and changed it back. :oops:
When I put it back on the correct way there was no flash or anything.
Is this normal?
Edit: It is still drivable and ok.
Daily Driver - Yellow Devil 76 Clubman
Restoration Project - Primer grey 66 Morris Mini Deluxe
PostPosted: Mon Jun 20, 2005 3:49 pm
ouch! my bro did that once..... :x fried his electrics! :lol:
PostPosted: Mon Jun 20, 2005 4:46 pm
well if it still charges and all other things work all ok.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
PostPosted: Mon Jun 20, 2005 4:48 pm
How do you know if a car is positive earth or negative earth?
PostPosted: Mon Jun 20, 2005 4:58 pm
They used to say on the boot floor if it is 98% are neg earth
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
 Post subject: battery
PostPosted: Mon Jun 20, 2005 5:45 pm
Simon,
Normally the car is negative earth if it has an
alternator fitted.
Its a lot easier if the car is neg earth
i.e.when fitting acessories such as a radio.
I changed my 66 deluxe from pos to neg earth when
I first bought it,it only takes a few minutes.
For anyone thats interested here are the instructions
from minimania site...
www.minimania.com/articlev.cfm?displayi ... ormation&c
Felix
1966 mustang coupe 289 auto
1970 mgb roadster auto
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
http://s160.photobucket.com/albums/t173/1966mini/
PostPosted: Mon Jun 20, 2005 7:28 pm
If you hook it up back to front, the alternator diodes all conduct to ground and you get a BIG short. Effect on wiring is not pretty....!
PostPosted: Mon Jun 20, 2005 7:47 pm
I'll say... I put the battery in backwards once and fried the whole lot, including alternator, starter solenoid, ALL the fuses. It put it in backwards because I wasn't paying attention to the terminals. The newer battery I had bought had the electrodes on the opposite side of the battery, so I rotated the battery around until it was the way before (towards the lefthand side on the top). Little did I know that now the electrodes were back to front... LOL!
"What's that smoke coming from? JESUS $&@*#*@ CHRISTOPHER!!! MY CAR!!!"
Jonathan
