OK gents,
I am undecided about doing this work myself or sending it to a pro. Can someone go over step by step on how to remove the drive shaft so that I have a fair idea on what needs to be done?
Background: Left inner pot joint boot is loose and has come off. Clunking noise from right outer CV, steering rack boot is busted.
TOOLS: Leyland manual, ball joint separator, torque wrench with 1 1/8 inch hub nut socket, regular socket set, mallet, impact driver for drum brake screws, cold beer waiting in fridge.
STEP1: Jack up both side of front of car with axle stands, chock back wheels, hand brake on etc. Take off wheel. Do I need to take off the brake drums too? or can I take it off as a whole unit including swivel hub and drive flange?
STEP2: Drain engine oil
STEP3: remove Hub nut cover (which right one is missing), take out hub nut split pin, Undo the hub Nut.
STEP4: Support the hub using jack or some other method
STEP5: undo the top and bottom ball joint nuts and steering arm nuts
STEP6: use ball joint separator tool (Can i use a ball joint separator fork instead??) to disconnect the upper and lower ball joints. Disconnect the steering arm joint
STEP7: Take out whole swivel hub, making sure to support the drive shaft and not let it dangle in mid air
STEP8: Yank out the drive shaft, CV, pot joint and all. Will it fit through the hole in the subframe? Looks mighty small…
STEP9: Disconnect outer CV from drive shaft. Cut Pot Joint boot. Disconnect the pot joint from drive shaft by knocking it with a mallet
STEP10: clean up everything! (big job, as the arms currently have 36 years of dirt on them). Clean the pot joint by taking all the balls out of the pot joint. What can I use to clean it with? Petrol? Degreaser or metholated spirits etc?
STEP11: Regrease everything up with half tube of CV grease. Rotate the shaft making sure everything is covered in grease.
STEP12: Check condition of CV joints by cutting the boot open and making sure there is still grease in the CV. If any other condition consult Doc Mini
. Grease it back up with half the tube of CV grease.
STEP13: Connect the CV back onto drive shaft, install new CV boot. Grease the CV boot up with remaining grease.
STEP14: Pop on a new boot for the Pot joint, pile in the remaining CV grease from tube. Use the tie thingies make sure everything is tight, drive shafts kept dry for a tight boot fit.
STEP15: reinstall drive shaft onto body, support shaft while swivel hubs are not yet on.
STEP16: Swivel hubs back on, tighten the hub nut to 50pounds (as per book) or all the way tight, undo it one turn. Pop on the split pin and hub cover. grease up the nipples and have a beer!
STEP17: Curse loudly, remove everything and put on the steering rack boot on
Questions:
0) HAVE I MISSED ANYTHING???
1) Do I need to take off the brake drums to remove the swivel hubs?
2) Must I use an expensive Ball joint remover or can I just use one of those 2 prong fork thingies?
3) Do the inner pot joint and outer CV joints use the same grease? Is this the same Lithium Grease that I use to grease up the ball joint nipples??
4) What do I use to degrease everything? Degreaser? Petrol? Metho? Simple cloth wipe?
5) When I take out the swivel hub is there anything that I need to remove before I can do that? Like circlips?
6) When I have everything out, what small cheap items should I be replacing? Like circlips, split pins etc? stuff that wears out often and should be replaced regularly
7) Do I need special tools to remove the wheel bearings and grease them up with HTB grease?
Anything else Doc?
The deal is if I do it myself i get to 1) learn, 2) save a bit of cash (maybe, cuase it will cost $300+ at the mechanics), 3) gloat that I did it myself...
What do you think? I know what Dr Mini's vote will be
