It is currently Mon Jun 30, 2025 5:22 pm
 Post subject: Alternative Brakes???
PostPosted: Thu Jun 23, 2005 6:13 pm
G'day
Just Wondering What alternative Disk Brakes there are around, and what is involved to replace 8.4 Disks... Im running 15" Alloys on my moke, so leaves a bit more room there to play with...
Daniel.
MOKE'N
PostPosted: Thu Jun 23, 2005 6:59 pm
ive got the metro turbo 8.4inch ventilated discs with 4 piston calipers on mine... Seem to work very good, pulled me up with ease at wakefield park hitting close to 200kph coming into the first corner. Done 15-20 laps and didnt get any brake fade either, running black stuff pads.
1974 Moke - 998cc
PostPosted: Thu Jun 23, 2005 7:04 pm
Yeah XR8 running the same system and they work very well. You cold probably look a running some other system but there would be alot of work trying to get them to fit on some sort of hub??
PostPosted: Thu Jun 23, 2005 9:49 pm
is there any reason why you guys opted for the metro turbo's instead of camiras?
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Thu Jun 23, 2005 10:16 pm
well there is no modification needed with the metros, bolt straight on. No need for engineers, tried and tested for years, 4 piston caliper v single piston, ventilated disc (not sure if camiras came ventilated) mine cost cheaper then the camiras, and also the benefit of not having anything on my car from a bloody CAMIRA :D
But having said that if i couldnt find a set of metro turbo brakes cheap enough i would have gone the camiras i think. But then again they need a mini disc hub, so maybe if i had drums id go the 9 inch honda conversion......
1974 Moke - 998cc
PostPosted: Thu Jun 23, 2005 10:17 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
brad the camiras can be done on drum hubs
makka
PostPosted: Thu Jun 23, 2005 11:15 pm
makka
.... but they do use disc type CVs.. :wink:
PostPosted: Thu Jun 23, 2005 11:18 pm
84 to 89 camiras had ventilated discs that were 9.25" diameter. im not sure if these are able to be used tho.
PostPosted: Fri Jun 24, 2005 9:16 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
no kev they can be done with the drum cv my mate machines the drive flange to suit
makka
PostPosted: Fri Jun 24, 2005 9:23 am
Makka,
Nuke Mini has disc CVs on his so I guess either way works.
If running big wheels or racing, the disc CV setup is lots stronger.. :wink:
PostPosted: Fri Jun 24, 2005 9:31 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
did you ever see the jax mini van from merryland ??? he raced it at eastern creek a bit big power 1275 gr built motor 13's and the disk conversion with the drum parts no worries
makka
PostPosted: Fri Jun 24, 2005 9:35 am
Ivan, from Mini Spares & Repairs told me he has broken them when raced. And that was with 998 power... :shock:
PostPosted: Fri Jun 24, 2005 10:09 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
dont know what he did but the ones alan makes have had no hassles
makka
PostPosted: Fri Jun 24, 2005 11:38 am
Are the Metro Turbo brakes hard to come across?
Anyone know someone selling some :lol:
Daniel.
MOKE'N
PostPosted: Fri Jun 24, 2005 11:44 am
theminiman is selling some 4pots for 8.4in solid disc cheap too
