It is currently Fri Jul 18, 2025 9:11 pm
PostPosted: Sat Jul 17, 2004 9:41 pm
i had changed the rocker cover gasket and tightened the bolt till i cant turn no more!!!
took the car for a long drive - abt 2 hours - came back n parked in my garaged
and the next day (b4 i left for brisbane), i did a check and found no oil stain! woohoo so i wave goodbye to my mini thinkin what a good job ive done! :lol:
but then when i returned earilier today (few days later) - again i took my mini for a little ride...just round the corner...and this time i found her drippin on the left handside of the car. AHHHH....
:cry: :cry: :cry:
98 brg rover
PostPosted: Sat Jul 17, 2004 10:40 pm
Okey dokey, a common mistake made with the cork rocker cover gaskets is overtightening them.
The cork will shrink a bit over time, and ya just tighten then up a nip every so often. Tightening it all the way up straight away doesnt necessarily mean it will stop it leaking.
I used to cheat with my old V8, by using a bead of Permatex Ultra-Copper and just lightly squeezing it down till it cured, then give it a tweak more. The rocker covers on that were a PITA since they would warp and leak all the time.
PostPosted: Sat Jul 17, 2004 11:28 pm
oh no...so what should i do now?...loosen the screws?...and replace again with a gasket?...or just let it pee pee every now n then....
98 brg rover
PostPosted: Sun Jul 18, 2004 7:01 am
More likely not the rocker cover gasket this time- probably the timing cover seal, or LH diff cover seal.
Clean the whole motor with degreaser, rinse it off, go for a 15 min run, then jack it up and look under. You should be able to see where it's coming out of. :wink:
