It is currently Sat Aug 02, 2025 7:16 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jul 03, 2005 5:51 pm
OK,
Radiator cap is fine, and I have a spare. Yes, it's the longneck version.
Timing is fine, I always check this myself after having a mechanic work on the lil girl.
I've done everything possible to remove any airlocks from the system. This overheating as been a problem for a long time now.
The only reason I hadnt considered the water pump MiniMan, is the fact that I couldnt be arsed changing it, and I didnt want to look LOL. Quite possibly a culprit as much as the rest, though. The water pump would only be about 20 000 k's old, so it SHOULDNT be stuffed, but I'll have to check if it's circulating properly to make sure.
Even at idle the girl gets hot, but higher rev's really exacerbates the problem.
So now, prirorities are to check the hoses for any collapsing, the water pump, and the radiator. hmmmmmmmm.
"He's always been a dickhead, He always is a dickhead, He will always be a dickhead. So stop complaining when he acts like one."
 Post subject: toon
PostPosted: Sun Jul 03, 2005 6:53 pm
and that the engine ain't running lean for any reason like sucking air from a manifold or carby gasket...... that is, assuming you are jetted right etc :wink:
PostPosted: Sun Jul 03, 2005 7:05 pm
nope, no manifold leaks or such. And I think the HIF44 is much more suitable than the 1 1/4 su it was running beforehand LOL.
Yeah, in case yer reading this Makka, I finally got that carby fitted. Gawd, I'm a lazy so and so.
PostPosted: Sun Jul 03, 2005 7:12 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
jsut sus out the mixture on it phil cos my car had overheating problems :(
i'm wondering if the so called expert who adjusted the carb last did it right
cos i had never really known much about this carb i took it to a "expert"...
makka
sorry i should elaborate cos at the same time i had a electronic ignition put on and some other bit's and pices and thats when the over heating started and i thought it was the ignition i never tried the carb :(
PostPosted: Sun Jul 03, 2005 7:26 pm
thanks for the reply mate. just changed the needle and seat, coz it had corroded up a bit. Mixture was pretty damn lean(set by the "specialist" for mini's in this town.
Has since been sorted, but we're still looking at messing with some more needles
I've sorted that BDK or BDL would be a suitable needle(WINSU, great little program). Will give Midel a ring and get a couple sent up, and see how they go
PostPosted: Sun Jul 03, 2005 9:41 pm
Specak to...Silvo...Bill Siverton
He'll look after you :wink:
Users browsing this forum: bharp831 and 76 guests
