It is currently Sat Aug 02, 2025 5:29 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Jul 05, 2005 8:19 pm
"I'd think that 6psi would give around a 50% power increase"
as a rough rule of thumb, 7Psi = equivalent of a 50% displacement increase....
so a 998 @ 7psi, should have the torque of a 1500cc ....
As you can see, its not really a close rule of thumb, but it does work...
I'm making nearly 3 times the factory output of a 998 (about 25 @ Wheels) but I'm not making the torque of a 1500cc ..... I think its all in the breathing...
I'll report back when the 12G1316 DRMINI ST head is on and its all dyno'd up ....
I'm expecting about 100@wheels and a Load more torque - Planning to be running at 14Psi . . . to theory says i should have the torque of a 2 litre !! (as-if!)
the theory is based on atmospheric pressure of 14.7Psi producing stock torque.... therefore 50% air pressure should equal 50% more torque... geddit ?
Later
J
PostPosted: Tue Jul 05, 2005 8:51 pm
The engine will handle 7psi OK as long it is in good nic
I have heard of standard 1100's making 70hp at wheels with 8psi using these
blowers easy
I think one of my kits will fit even with that radiator hose assembly
4efte powered Clubman
supercharged 998 race car
PostPosted: Tue Jul 05, 2005 10:11 pm
Oh cool. Good to hear 8)
Ben, i'll order the kit in about 6-8 weeks. :)
PostPosted: Wed Jul 06, 2005 12:26 am
Might also be a good idea to invest in some aftermarket gauges...
Oil pressure
Oil temp
Water temp
Maybe....
PostPosted: Wed Jul 06, 2005 12:27 am
Check my other thread :)
I beat you to it.
I anticipated what you were thinking, even though i hadn't spoken to you for a while... isnt that good 8)
PostPosted: Wed Jul 06, 2005 1:07 am
Check your other thread :wink:
I knew you'd come up with a stupid P-plater idea so i pointed out a better thing to do. :lol:
PostPosted: Wed Jul 06, 2005 9:41 am
*cough* brake fade *cough*
PostPosted: Wed Jul 06, 2005 3:16 pm
The brakes may fade but the speed never will. :wink:
The brakes are fine now that i get them adjusted every now and then :lol:
MC... still no bloody mini! Whats going on mate?
PostPosted: Wed Jul 06, 2005 3:18 pm
PostPosted: Wed Jul 06, 2005 3:51 pm
Question: Has anyone actually got a running car with one of these SC12 supercharger kits? If so, do you get much more power? Any pics?
PostPosted: Wed Jul 06, 2005 4:17 pm
http://www.ausmini.com/forums/viewtopic ... bloke+(Ben)#20140
i've got pictures of it somewhere....edit (found it)
note the spacer on the bonnet hinge
edit...
hehe... found this..:shock:
PostPosted: Wed Jul 06, 2005 4:32 pm
Later
J
Does all that allow for blower drive losses.? I saw a Top Gear episode where Clarkson was testing the supercharged W12 Bentley and the blower drive in that consumes 120HP.
Chris
Everything I like is either
PostPosted: Wed Jul 06, 2005 5:18 pm
Thanx cushy
Users browsing this forum: Bing [Bot] and 93 guests
